Just hit 140,000 miles what maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NightShades, Feb 17, 2018.
  1. Feb 17, 2018 at 11:14 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    I've used this in other Toyotas and wouldn't hesitate to use it again, actually.
  2. Feb 17, 2018 at 11:20 AM
    Trachito
    New Orleans
    What do you mean it gives the crank then dies? It starts then shuts off?
    If it won't turn over at all, I'd guess a loose connection at the battery, starter, or starter solenoid, or any of those parts being bad, as well as the ignition switch.
  3. Feb 17, 2018 at 11:22 AM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    ^^ this. From what I've read, you may not want to flush. Personally, I wouldn't want to risk it with a full flush if I wasn't having problems to begin with.
    Also, I'd imagine your plug gaps are somewhat altered at that mileage. Also, be careful you don't twist one off when removing.
  4. Feb 17, 2018 at 11:37 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Yep. Did a pan drop and filter change on my daughter's Yaris with 126k on the clock. Followed by 2 more drain and fills with MaxLife. Zero issues.
    My Taco is under the Platinum Warranty until 125k. I'll start doing a few drain and fills at around 75k with WS just to keep Toyota happy. But after 125k....she'll see nothing but MaxLife with regular DAFs.
  5. Feb 17, 2018 at 12:40 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I called my dealer about this exact thing a while back. They said they don’t recommend a full flush, even at lower mileage. Just a drain and refill.
  6. Feb 17, 2018 at 1:48 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I have done regular maintenance on my truck since new. It now has 275k and I just had an ATF full flush done for the first time. I asked the dealer about it at 130k and the technician said "leave it be at that point". Once I hit 250k I started to get concerned, its petroleum and breaks down just as engine oil does. I figured its more of a risk leaving the ATF be than flushing and filling with new at this mileage.
  7. Feb 17, 2018 at 8:06 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Whats everybodys average cost for a 100k service? My carfax service report said it had regular services up to 95k miles. So, I believe Ill be okay for awhile. Just looking for what to expect
  8. Feb 17, 2018 at 8:42 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Agree, haven't seen much about this being an issue. 150k miles here with no fuel issues
  9. Feb 18, 2018 at 9:51 AM
    270wsm
    270wsm Well-Known Member
    AZ
    Clean the MAF and throttle body ,and rear and front ,transfer case fuild change,you can do it yourself save $ ,there is a writeup on here
  10. Feb 18, 2018 at 11:51 AM
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    This is what I did at 95k when I got the truck, along with ATF fluid change, Coolant change, and spark plugs.
    I'm still going to grease the driveshafts, change the fluid in the Transmission again, and change out the thermostat with the oil cooler I'm adding.
  11. Feb 18, 2018 at 7:01 PM
    Trachito
    New Orleans
    I do my own work, and I spend under $200 in all fluids and spark plugs. I'm also way more thorough than any mechanic.
