Just how good is the Tacoma Auto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by First Taco, May 21, 2012.
  1. May 23, 2012 at 9:25 AM
    #61
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  2. May 23, 2012 at 9:35 AM
    #62
    superwhite
    superwhite Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Interesting... Any more info on this? I hate how my truck shifts out of overdrive so quickly when going up a small hill.
  3. May 23, 2012 at 9:37 AM
    #63
    OZ-T
    Peter North
    British Columbia
    You sure what you are feeling isn't the torque converter unlocking ?
  4. May 23, 2012 at 9:38 AM
    #64
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yep look into FSM for A750 Manual shifting test. I know I saw it there. I dont think you can switch it on the fly so once in manual mode it will stay in manual mode until you reconnect cable.
  5. May 23, 2012 at 9:39 AM
    #65
    BlueT
    NorthEast
    I figure out him so few posts above :D Nice to have you back Whipp
  6. May 23, 2012 at 9:51 AM
    #66
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    isnt the auto advertised with better MPG? im pretty sure ive read on here that the auto has lower RPM's on the highways than the manual.
    Who the fuck doenst keep jumper cables in their ride?! If you dont then you should hand in your man/common sense card now.
  7. May 23, 2012 at 11:10 AM
    #67
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    [QUOTE
    Who the fuck doenst keep jumper cables in their ride?! If you dont then you should hand in your man/common sense card now.[/QUOTE]
    Workman......does not keep jumper cables in his ride. He will retain his man card though, cause he is a bad ass.
  8. May 23, 2012 at 11:21 AM
    #68
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Workman......does not keep jumper cables in his ride. He will retain his man card though, cause he is a bad ass.[/QUOTE]
    I still stand by my "common sense" comment. Why not have the option to help yourself if the situation ever arises?
  9. May 23, 2012 at 11:30 AM
    #69
    Workman
    Workman agrees that Jumper cables are a good idea. Lots of places out here where Workman goes you might not see anyone for weeks. Would be nice in a parking lot though or just to lend a helping hand.
    Workman gets paid to hike, and is always prepared to hike out with plenty of water, food, shelter and .357mag with a box of 50 rounds.
  10. May 23, 2012 at 11:32 AM
    #70
    OZ-T
    Peter North
    British Columbia
    OZ would suggest a jump pack however dhk , er I mean Knucklehead claims BCAA knows nothing and they won't start a dead vehicle
  11. May 23, 2012 at 11:36 AM
    #71
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you guys understood the OP's post? i am trying to read this out loud..it is like haiku!
    someone translate so i can participate.
  12. May 23, 2012 at 11:38 AM
    #72
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    He had a manual, than he got an auto, and loves it.
  13. May 23, 2012 at 11:39 AM
    #73
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    truck-wise, i will always get a auto, easier to off-road,
    car-wise, i will always get manual, more fun
  14. May 23, 2012 at 11:41 AM
    #74
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    zombie runner says that the jump packs work fine as long as they have a good charge and are not left in the truck and neglected.
  15. May 23, 2012 at 12:17 PM
    #75
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Brake pads do need to be replaced much more often I think with an auto. I think in general in the long run an auto will require more maintenance $$$$'s.
  16. May 23, 2012 at 12:19 PM
    #76
    legga400
    legga400 Active Member
    Massachusetts
    TRD Sport
    working on it...
    I enjoy the automatic in traffic.... I have an Nightster for my shifting fix.. :D
  17. May 23, 2012 at 12:38 PM
    #77
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The automatic makes OffroadToy a happy camper.:woot:
  18. May 23, 2012 at 12:41 PM
    #78
    monkeyface
    Colorado
    Question - with the auto, if you put it into the 2 or 3 position, do you start out in 2nd or 3rd gear, or do you still start out in 1st gear?
  19. May 23, 2012 at 12:57 PM
    #79
    jkib
    jkib Member
    08 Tacoma DC SB
    Bilsteen 5100's, Weston steps
    I don't think your buddy knows how to use the auto.
  20. May 23, 2012 at 1:06 PM
    #80
    aficianado
    back to bone stock.
    hahahha..that is what that he is saying? i can move his punctuation marks around and still not get it. thanks.
