Just installed 4.88 gears and lockers and 33's but highway driving sucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coganhagen01, Jul 18, 2021.
  1. Jul 26, 2021 at 8:23 PM
    #41
    HoytK9
    HoytK9 Well-Known Member
    Voodoo Blue 2019 TRD Pro
    Snug Top Hi-Liner
    Do you have anything that adds weight such as bumpers, winch, full skids, RTT, etc? 3500 RPMS at 75mph sounds ideal to me!
  2. Jul 26, 2021 at 8:34 PM
    #42
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Sliders and a tube front bumper but other than that not much added weight. It’s a 4 banger so more revs are not a bad thing, but it is a little excessive at times lol. If you dont drive a bunch on the hwy, it makes it really peppy around town which is nice
  3. Jul 27, 2021 at 7:48 AM
    #43
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Adding weight is not going to change the RPM.
    I'm getting 4.56 gears next month for my 34's (actually 33.86" per manufacture specs). I do alot of highway driving between camping locations, so I do not want very high RPM's when cruising. With the 4.56 gears and 80 mph I should be turning 2606 RPM. Think thats perfect IMO.
    coganhagen01[OP] likes this.
  4. Jul 27, 2021 at 8:57 AM
    #44
    Carson01
    Carson01 Well-Known Member
    Carson
    06 Silver tacoma TRD OR
    Just installed 4.56 gears from ECGS, I'm on 33s right now but planning on going to 35s, I turn around 2600-2700 rpm at 80mph with the 33s, with 35s it should be perfect!
  5. Aug 4, 2021 at 5:33 AM
    #45
    awylie0321
    awylie0321 Member
    Andy
    15 TSS
    None Yet
    Carson01 sorry to bug you but when you say "perfect" are you expecting the RPM's to drop? If so by how much? TIA
  6. Aug 4, 2021 at 7:20 AM
    #46
    Carson01
    Carson
    with 35s I should be sitting right at 3k rpm at 70! so the rpms will drop slightly but will not cause the transmission to start searching for gears!
  7. Aug 4, 2021 at 7:39 AM
    #47
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You need to change to a different overall gear ratio.
    Changing from a (example) 4.10 rear end to a 4.88 rear end means the engine, transmission need to generate more revolutions for a given speed. You essentially LOWERED the gear ratio. You need a HIGHER ratio to reduce the engine revolutions.
    This is why Overdrive transmissions are typically 1:1 or higher (0.9:1)
  8. Aug 4, 2021 at 7:56 AM
    #48
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm at 2400-2500 rpms at 70mph on 35s and 4.88. Auto 4.0.
    awylie0321 likes this.
  9. Aug 4, 2021 at 8:09 AM
    #49
    Butt Ugly Chuck
    Butt Ugly Chuck Member
    In a Taco DOWN BY THE RIVER!
    2005 White Access Cab 6sp
    Do floor mats count? ;)
    I run 275/80 R17 (32.7" dia) and 4.30 gears with a 6 speed manual.
    I turn 2,700 RPM to run 70 MPH. Just about perfect for "33s"
    Butt
