just installed a new hitch
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Aug 7, 2010.
  1. Aug 7, 2010 at 10:27 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    but i have one question, what wiring do i need to buy to set up for a four prong trailer, and also where do i plug this in? do i need to splice wires? TIA
  2. Aug 7, 2010 at 10:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Does your truck have any trailer wiring at all? If not, you need to get power from the tail lights and the amber turn signals, then get a 5 to 4 converter box so the separate amber turn signals on the truck power the turn signals for the trailer since it uses the actual tail light.
    You will have one wire from each amber light, one for brakes (can come from either light on the truck), one for tail (can also come from either light), and one ground going into the box. Then you will have left and right turn, tail, and ground coming out to the 4 prong plug.
    sorry if that was confusing lol.
  3. Aug 7, 2010 at 10:57 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Basically you buy a $30kit from autozone, and it's plug and play. Just have to remove tail lights to install and no splices.
  4. Aug 7, 2010 at 11:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    or that haha. I just converted my 4 prong to a 5 prong to have brakes and had to redo all the wiring because the uhaul retards that did it originally are retarded. They had nothing but scotch blocks for the splices and half of them were not getting a good connection.
  5. Aug 8, 2010 at 4:18 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    well my truck was never setup for towing, does that mean i need to do splicing? or do all tacomas have the same wiring harness and i can just buy the kit and plug it in and run the wires?
  6. Aug 8, 2010 at 4:39 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    love it stev0
  7. Aug 8, 2010 at 4:46 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    Just go to Auto Zone, go to the towing section and you will see a bunch of packages that have the wiring all ready to go. Find your year/model truck, and you take the tail light out and plug the trailer wiring into it.
  8. Aug 8, 2010 at 5:12 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, plug and play kits are the way to go for a 4-prong. no need to slipce wires unless you are looking for a weekend project.
  9. Aug 8, 2010 at 11:01 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    X2... I've already had one of their convertor boxes fry and another may have. I gotta go with something else this time
  10. Aug 9, 2010 at 12:08 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    You need a wiring harness. It will run you from $30-$60. They are easy to install. They come with simple instructions. Best to get the plug n play kit. Not the one you have to splice wires. I have installed 3 of these in 2 Tacomas. Takes less than 30minutes. Biggest hassle is removing your tail lights to plug the wire into them.
  11. Aug 9, 2010 at 12:11 AM
    genxer36
    Sean
    Bethlehem,GA
  12. Aug 10, 2010 at 10:36 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    so i went to autozone and found the right kit for my truck. i literally takes about twenty minutes to install, the longest part was drilling the hole for the ground. thanks for the help guys
