Just Installed a Powertrax No Slip AKA Lunchbox Locker in my 2nd gen
Discussion in 'Technical Chat' started by EatSleepTacos, Jul 30, 2018.
  1. Aug 14, 2018 at 3:27 PM
    #61
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
    I give you full credit for the idea of a lunchbox locker. You've been wanting to do it longer than I have! You just convinced me to pull the trigger before you did.
    That sounds like a hell of a fun time.
    BravesRunner[QUOTED] likes this.
  2. Aug 14, 2018 at 3:35 PM
    #62
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    In for the Rausch report!
    So with one of these if you have one rear tire in the air and try to accelerate the rear will be locked, right?
  3. Aug 14, 2018 at 3:38 PM
    #63
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, that's correct! The video I'll get at Rausch will illustrate that perfectly. Of course when I go, I'll be sure to post in here.
    05Taco4x4 and 16Tacos[QUOTED] like this.
  4. Aug 14, 2018 at 3:39 PM
    #64
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    The way a mechanical locker works is it has to overcome spring pressure to "ratchet" they are permanently locked together until that happens. It unlocks and ratchets when the wheels need different speeds like going around a corner.
    toysrgood likes this.
  5. Aug 14, 2018 at 4:18 PM
    #65
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    It just took you buying it and putting it in to get me to buy one. I was dragging my feet with it.
    And I’m all about some “FULL SEND” :mudding:
  6. Aug 14, 2018 at 4:25 PM
    #66
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Have you seen the YouTube videos of Rausch and AOAA?
  7. Aug 14, 2018 at 4:26 PM
    #67
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    Everyone who watches you off the road walks away impressed.
  8. Aug 14, 2018 at 4:28 PM
    #68
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    My tow strap is permanently attached to the back of the truck for Adam. But he'll send it that's for sure!!!
    BravesRunner likes this.
  9. Aug 14, 2018 at 5:14 PM
    #69
    BravesRunner
    Adam
    SC
    I haven’t yet but I definitely will to see why I’m up against!
    I get more and more confident every time I go out. I just follow directions from people that have more experience and it’s worked in my favor so far so I give them all the credit!
    Just there for insurance!
  10. Aug 14, 2018 at 5:24 PM
    #70
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here’s the hill I’ll be doing with a locker. As you can see, it’s very flexy and I struggled on it with an open diff the first time I did it.
    https://youtu.be/Q9aUTFPjgR4?t=119
  11. Aug 14, 2018 at 5:31 PM
    #71
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    How steep is that hill looks like it's probably a lot like Dutch john at URE the video I shared of the jeep going down it. When I go up that hill I hit it doing like 10 mph and am on the wheel hard hunting for the next traction spot to pull me up until the rear wheels get traction then repeat.
  12. Aug 14, 2018 at 5:32 PM
    #72
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s fairly steep but not that long. Maybe 150’? It’s fun.
    ovrlndkull[QUOTED] likes this.
  13. Aug 14, 2018 at 5:35 PM
    #73
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Dutch may be a little steeper it's hard to tell video wise without doing or seeing them both. Dutch is Probably the same length but there is a rip rap section at the beginning and then dirt at the end with some small humps to make it closer to 200 ft or so.
  14. Aug 14, 2018 at 5:40 PM
    #74
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah that's where a locker shines over a limited slip diff although you could trick it by lightly applying the ebrake
  15. Aug 14, 2018 at 5:43 PM
    #75
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Using the pedal works better for a limited slip a click or 2 on the ebrake works OKish when doing a really slow crawl climb on open diffs.
  16. Aug 14, 2018 at 5:44 PM
    #76
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    @Nitori
    Was this what you were talking about before?
  17. Aug 14, 2018 at 6:37 PM
    #77
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    No... Well, sort of. What I was talking about was a rebuild kit for the OEM clutch type LSD using more performance oriented friction materials.
    I won't bore everyone with a write up explaining all the details and theory of application, but TL;DR "lunchbox" lockers or other selectable lockers are solid ratcheting mechanical units that have an on/off sort of engagement where they split torque 50/50, whereas clutch types are more "progressive" and gentle in their engagement, depending on friction material and spring strength.
    It's really just like upgrading the clutch in a manual transmission, you're making the friction surface more bite-y and aggressive.
    TACOVRD[QUOTED] likes this.
  18. Aug 14, 2018 at 6:40 PM
    #78
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Which LSD would you add? After ‘08 all the LSD’s in these trucks are really just simulated with brakes and electronics so the diff is still technically open.
  19. Aug 14, 2018 at 6:42 PM
    #79
    Nitori
    Maricopa AZ
    2021 T4R SR5
    A pre-08 LSD, rebuilt with better friction rings. :)
  20. Aug 14, 2018 at 6:44 PM
    #80
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m curious about this project now. Would you just swap in an entire 2nd gen axle?
