Just Installed AFE Stage 2 Si Intake....
Discussion in 'Performance and Tuning' started by WOODEX M.E., May 16, 2015.
  1. May 16, 2015 at 1:44 PM
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    So I just installed the above mentioned intake on my Tacoma yesterday. I like that the supercharger is much louder now. I ran it this morning and did a couple 2nd and 3rd gear pulls, But I noticed something strange (well a few strange things).
    It was 56F outside this morning and I seem to be running more rich than before according to my gauge, which is fine by me really. I plan on switching to a 2.825 pulley in a few months. Also When I was at peak boost I was reading at 7psi! I never see above 6.1-6.2 in the summer (55F-70F) unless its near freezing out. Usually at 7psi when its 30F out and 8psi when its -20F. Anyone else have an opinion on this?
    But yeah, I'm not complaining, just curious. So far I like the new noise and what feels like peppier throttle response. The butt dyno doesn't really notice anything but whatever. Wasn't really expecting anything either.
  2. May 19, 2015 at 8:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well if it stays at that psi regularly, then it isn't because of some weather anomaly D.A. change. It definitely breathes easier. Which is less restriction from a laminar flow point.
    Justus likes this.
  3. May 20, 2015 at 9:55 AM
    WOODEX M.E.
    Corey
    Maine
    Yeah, that's what I figured, but I didn't want to come on here spouting some BS. Intakes have a lot of mixed reviews on this site, which is understandable. They all act differently under different circumstances. Its kind of cool to see an indicated 0.8 psi bump from it though. Not sure if I gained anything from it or not power wise. Either way the 2.825 URD pulley is going to find its way into the mix in about 2 months based on mileage estimates. Hopefully ill be able to feel a power bump from it then.
  4. May 20, 2015 at 11:26 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The pulley will wake things up.
  5. May 20, 2015 at 11:33 AM
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    Did you reset your ECU after installing the intake? It may have to re-learn things using the sensors after making a change like that.
    Torspd likes this.
  6. May 20, 2015 at 12:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Agreed. :thumbsup:
  7. May 20, 2015 at 5:59 PM
    WOODEX M.E.
    Corey
    Maine
    No I didnt do/reset anything, but i have driven it about 400miles since install. Nothing has really changed. Not that anything feel wrong.
  8. Jun 18, 2015 at 6:52 PM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    You guys think that the intake and 2.82 pulley will need to be programmed again after the original TRD programming that Toyota does? What about the 2.85?
  9. Jun 18, 2015 at 6:55 PM
    6xchamps
    Fuquay Varina NC
    2015 AC
    What a perfect, prompt enjoyable answer lol
