Just installed icons coilovers on my 03 taco double cab. Have a few questions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Sep 14, 2014.
  1. Sep 14, 2014 at 8:58 AM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    I just installed some icons coilovers adjusted to 3 inch lift on my 03 taco double cab. The ride is still a bit stiff on the road. I know it's a truck and it still going to ride stiffer then a small car but is there anything else I can do to make it run a bit smoother? Maybe take some air out of tires? Change ball joints? What do you guys recommend ? Thanks
  2. Sep 14, 2014 at 8:59 AM
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    stock bumper in front? were the coilovers new or used?
  3. Sep 14, 2014 at 9:00 AM
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    No experience with Icons but usually 3 inches of lift is right around the max on a lot of coilovers. Turning them down some would likely smooth it out, but you'd lose some lift
  4. Sep 14, 2014 at 9:04 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Yeah 3" is max per Icon's adjustment guide.
    Either lower them down .5"-1" or drop the psi from 250 to 200.
  5. Sep 14, 2014 at 9:05 AM
    Junetaco03
    After market bumper. I have a bar bumber with 3 hella lights on the front. I bought them off my best friend. He only had them for 3k miles. I drove his car truck before I bought it and it had better ride quality then mine. That's why I purchase them.
  6. Sep 14, 2014 at 9:06 AM
    Junetaco03
    Ok thanks I'll try to lower it 5" and see what's happens.
  7. Sep 14, 2014 at 9:09 AM
    munkel
    PDX
    I agree with what everyone else has said about dropping them down a bit BUT if you really want 3 inches then consider the following: what springs are in them, 650 or 700 and then if your bumper is heavy with a winch etc you may want to get the 700's and crank them down less. Assumes they are cranked down pretty far to compensate for heavy front end. All that said it is a truck and you have reached the max for Icons, it will be rougher than running them at 2 inches.
  8. Sep 14, 2014 at 9:09 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Yeah you'll notice a difference at 2.5" over 3". Also if you really wanted to you could bump up to a 14" 600lb spring instead of the 13" 650lb springs that are stock on Icons. It will soften the ride and probably keep the same preload even with the bumper.
  9. Sep 14, 2014 at 9:11 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    What tire pressure you running?
    How much preload on the C/Os?
  10. Sep 14, 2014 at 9:17 AM
    Junetaco03
    I'll have to check on the preside and 650 I believe on the preload.
  11. Sep 14, 2014 at 9:17 AM
    Junetaco03
    I have a front diff drop at home too. You think installing that will help a bit?
  12. Sep 14, 2014 at 9:19 AM
    License2Ill
    Ian
    Just lower the coils, no need for a dd if the co's are adjustable.
  13. Sep 14, 2014 at 9:21 AM
    Junetaco03
    Ok thanks for the tip
  14. Sep 14, 2014 at 9:21 AM
    tomtom
    The Desert SW
    2012 FJ
    The diff drop has more to do with drive shaft angles.
    Preload is easiest measured in inches. It is how much you compressed the springs, via the adjustment collar, to get the ride height you want.
    As others are suggesting, you might want to unload the front springs some to get more comfort but it will drop the nose down.
  15. Sep 14, 2014 at 9:21 AM
    License2Ill
    Ian
    And lower the psi of the shock, by 25-50 psi.
