Just Installed K & N 77 series CAI
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Delrivpilot, Dec 21, 2010.
  1. Dec 21, 2010 at 10:55 AM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I bought a K & N 77 Series cai on ebay and just had it put it. Lovin it so far. I expected more growling when the truck was idling. Not an issue. I pulled out into traffic and gunned it and it sounded awesome. Feels a bit peppier too. The only issue I have, is I am hearing a rattling noise when I start up or am running slowly like in a parking lot. I checked everything to see if there was anything loose, but didnt find anything. Wondering if anyone else had similar issue. IMG_0529.jpg
  2. Dec 21, 2010 at 11:14 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks Stan, I will check that. How long did you have it, and why did you dump it?
  3. Dec 21, 2010 at 2:28 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Gotcha. Yeah, I'm going to see how I make out with it and if it is sucking too much fuel, I will go back to stock.
  4. Jan 24, 2011 at 7:41 AM
    509TACO
    509TACO Member
    Did you ever figure out your rattle? Just installed my K&N 77 series and am getting the same rattle between 1st and 2nd lag if I'm not on it. I am wondering if it is a timing/running lean condition.
  5. Jan 24, 2011 at 8:05 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    Krookz so you report worse mileage with the K&N intake installed... could this have been due to your driving habits changing?
  6. Jan 24, 2011 at 8:37 AM
    509TACO
    509TACO Member
    Yes, I read that. Just wondering if that helped Delrivpilot. I will check the clearance around the filter and make sure everything is tightened down.
    Thanks
  7. Jan 24, 2011 at 9:59 AM
    509TACO
    509TACO Member
    You were right. Put a rubber gasket around the metal heat shield and no more noise.
    Thanks
  8. Jan 24, 2011 at 10:52 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    good choice!!
    i have the same one on my truck and i love it :)
    never ran into the rattling problem though :(
  9. Jan 24, 2011 at 11:31 AM
    509TACO
    509TACO Member
    You must be one of the few on here that like it. A lot of negative things about it, but so far I like it. When you get on it, it really wakes up.
  10. Jan 24, 2011 at 6:08 PM
    phat_ride_69
    phat_ride_69 Active Member
    Jack
    Calgary, AB
    2010 TRD Sport DCLB w/ JBL
    Westin Bull Bar with KC off road lamps, Nfab step bars, 5100's All Around, 1" Rear Spacer, 77 Series K&N Polished Intake,
    I've got the same one, I love it too especially when gunning it!! Take the engine cover off, looks way better IMHO.
