Just installed my MX4 Bakflip, drilling holes for drainage...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by APynckel, Apr 16, 2018.
  1. Apr 16, 2018 at 6:41 PM
    APynckel
    APynckel [OP] Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    So I am tempted to go get some sleek silicone tubing (instead of the corregated stuff the MFG sends) and drill a hole (required any way you do it, so it seams) up near the top of the bed to get the water out ASAP instead of minimizing the factory drain holes / enlarging them. Has anyone gone this route?
  2. May 7, 2018 at 3:44 PM
    17TRD
    17TRD Well-Known Member
    2017 TRD OR 4X4 DCSB
    20180507_172948.jpg Yes. 1/4 × 3/8" hose barb. Black corrugated tubing is invisible in the dark corners.
    Rob Daman likes this.
  3. May 7, 2018 at 5:16 PM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    I used the factory drain holes on my 2014, found a brass fitting that fit the factory bed holes and had a barbed end that fit the clear plastic drain hose. Have had no water issues, i don't believe the amount of water leakage is substantial.
  4. May 7, 2018 at 5:52 PM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    I hope you put silicone under the rails sides because it leaks under the rail rubber seal. Also in front bulkhead corners. Just close the cover and look at top corners you'll see the daylight.
  5. Jul 6, 2018 at 11:28 AM
    TacomaXSP6
    TacomaXSP6 Member
    Josh
    Greenville, SC
    2018 TRD Sport SB - Premium Package
    Did you run into any issues with drilling the holes in the top of wheel well? Anything in the way that I should know about before I do it?
  6. Jul 6, 2018 at 1:06 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    No holes drilled. Drains fine. Unnecessary holes.
