Just Installed: New Powerstop Brakes and HEL Performance Brake Lines
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomethingNew71, Feb 21, 2024.
  1. Mar 31, 2024 at 5:14 PM
    SomethingNew71
    SomethingNew71 [OP] Well-Known Member
    Cole
    2021 Army Green Tacoma TRD Sport, 1960 Mini Cooper
    All good! Straight stainless look would be the clear. Personally if you arent looking for a specific color, I would go with Carbon, or Clear. My favorite is Carbon. Clear is the same protective covering(just clear) over the standard stainless lines.
    I can totally see how that would be confusing given my initial post, sorry about that. I am not selling rotors or pads as you can get those via powerstop for much cheaper than I could ever hop to offer them. My link is for the front and rear brake lines and clips only. :)
    I am looking forward to seeing how these powerstop pads hold up over the next couple years. Pads are cheap so if they dont work out, I cant always go back to OEM pads.
  2. Mar 31, 2024 at 6:17 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    What are the lengths of the front lines you are offering? The factory lines are 11" and most places that sell factory replacement stainless braided lines are usually 1" longer (which works perfect for my application). I tried running longer lines, but they hit the bump stop mount and rub through the protective coating on the lines.
    If you are not interested in selling the lines separately (front or rear at least), what fittings do you use? I would order some lines directly from HEL, but I am not sure what our fittings are.
  3. Mar 31, 2024 at 6:23 PM
    SomethingNew71
    Cole
    Hey Nick, I matched OEM spec 1:1 of the OEM length lines, as I don't like carrying things that say they are OEM only to be slightly different. Regarding the fittings, they are the Toyota OE clip style. So the exact same kind that are on the OE rubber lines.
  4. Mar 31, 2024 at 6:33 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Ok, that's good, the OEM length is 11". But how much longer are your extended and super extended length over stock?
    Also regarding the fittings, on HEL's website, which fittings did you choose? I am assuming the swivel circlip female extended barrel (which have M10x1.00 threads with a convex seat)?
  5. Mar 31, 2024 at 6:43 PM
    SomethingNew71
    Cole
    I will need to doublecheck with my HEL contact here in the US to confirm the fitting but they are M10x1.00 to mate with the OE hard lines. They speced it to match the toyota fitting 1:1. Regarding lengths
    • OE Front - 11in (from end of fitting to end of fitting line is 12")
    • OE Rear -20in
    • Ext Front - 16.75in
    • Ext Rear - 24in
    • Ultra Ext Front - 20in
    • Ultra Ext Rear - 29in
  6. Mar 31, 2024 at 6:46 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Perfect, I appreciate the info!
  7. Mar 31, 2024 at 6:47 PM
    SomethingNew71
    Cole
    No problem happy to help! In fact I should add these lengths to my site anyways. Thanks for asking.
    nickonfire700[QUOTED] likes this.
  8. Apr 1, 2024 at 4:33 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Not a fan at all of drilled rotors, have seen them crack on friends cars during racing. I go with either slotted or smooth face because of that
  9. Apr 1, 2024 at 6:21 AM
    SomethingNew71
    Cole
    Racing vs daily driving a truck on the road are def different use cases for sure. Racing puts insane amounts of stress and heat on the brakes. Many OEM's sell vehicles with drilled rotors straight from factory. Totally down to your risk tolerance but in my opinion its an apples to oranges comparison.
    abou824[QUOTED] likes this.
  10. Apr 2, 2024 at 9:54 AM
    DD619
    DD619 Active Member
    Don
    San Diego, CA
    2020 White TRD OR
    Just bought red extended lines!
  11. Apr 2, 2024 at 10:39 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    Order submitted. Thank you.
  12. Apr 2, 2024 at 11:05 AM
    SomethingNew71
    Cole
    Thank you very much! Will get it to production now. :)
  13. Apr 2, 2024 at 11:28 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    All this excitement and you have the same stopping distance as before. That is awesome! Well except for the cool looking rotors and the sweet gold lines.
  14. Apr 2, 2024 at 11:32 AM
    SomethingNew71
    Cole
    My goal with the rotors and pads was to increase stopping force while towing. To that end I have achieved my goal. :)
    s0dhi and RushT like this.
  15. Apr 2, 2024 at 11:48 AM
    #35
    SomethingNew71
    Cole
    Thank you so much!
  16. Apr 2, 2024 at 2:16 PM
    #36
    Sungod
    St Augustine
    If you are towing, that makes sense. The slotted and drilled rotors will help out immensely with heat dissipation. Sadly most people think that putting big name brakes on their truck will magically reduce their stopping distance.
    s0dhi likes this.
  17. Apr 4, 2024 at 4:41 PM
    #37
    SomethingNew71
    Cole
    The first two red sets are off to their respective owners!
    Buggin112 and DD619 like this.
  18. Apr 4, 2024 at 5:28 PM
    #38
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Damn… I might have to go red. Post up pics of the first orange going out?
  19. Apr 4, 2024 at 5:43 PM
    #39
    SomethingNew71
    Cole
    Orange actually isn’t a super common order color for us. Even my Classic Mini lines i might have only sold one pair of orange lines in the last 4 years. It’s a super unique look though. I love them and wish more people got them! You could be the first one!
  20. Apr 4, 2024 at 6:10 PM
    #40
    twtaco$
    twtaco$ Well-Known Member
    What about the people driving behind you on their phone? Do they stop?
