Just installed new tire ?
Discussion in 'Wheels & Tires' started by OldDog, Feb 29, 2012.
  1. Feb 29, 2012 at 3:20 PM
    OldDog
    OldDog [OP] Well-Known Member
    w.mass
    2010 reg cab 4X4
    I recently installed Michelin ms2.s 265/70/16 on my (Stock)2010 reg cab. I did the chalk test and ended up with 32psi. There so much better then the stock Dunlop 245/75/16 . The only thing I've noticed is that the ride is bouncer. Do you think I should raise the psi, or is it that the shocks are having a harder time handling the extra weight of the new tire's ( 5lbs. or each tire) ?
  2. Feb 29, 2012 at 3:30 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The shocks aren't effected by the weight of the tires. Unless you go airborne.
  3. Feb 29, 2012 at 3:31 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I think what you are noticing is the wider tire (265). I installed the same tire and size on my regular cab. The Michelins are confidence inspiring aren't they, compared to the Dunlops?
  4. Feb 29, 2012 at 3:36 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    09 Black Access Cab 4x2
    Some stuff
    I am a bit confused, I thought the truck was delievered stock with Duncrap tires? :notsure:
  5. Feb 29, 2012 at 3:38 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    do not inflate more than 32psi. If you do the tires go on its "tippy toes" and you dont have good traction and it will also cause premature tire ware. Our trucks i think are listed at 29 psi on the door jam.
  6. Feb 29, 2012 at 3:40 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    That listing is for the factory tires .
  7. Feb 29, 2012 at 5:06 PM
    OldDog
    w.mass
    2010 reg cab 4X4
    Yes they are. Just tested them out in the snow. ....I couldn't be happier. I think there the best road tire made.
