Just installed Opt7 LEDs in projectors and fogs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tasnowma, Jan 30, 2016.
  1. Apr 12, 2016 at 10:05 PM
    #521
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Dielectric grease would be a good option, just make sure not to get it inside the seals and on the connectors.
    MoQS[QUOTED] and Mike G like this.
  2. Apr 13, 2016 at 3:41 AM
    #522
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    That's what I used, so far no issues.
  3. Apr 13, 2016 at 6:36 AM
    #523
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    I saw someone use electrical tape on theirs, and I plan to do the same on mine one of these days.
  4. Apr 14, 2016 at 12:24 PM
    #524
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    I just used the grease after replacement. Also ziptied them so water does not drip 'down' into the plugs
    ExtraExtra likes this.
  5. Apr 16, 2016 at 6:38 PM
    #525
    stormtrd
    stormtrd Well-Known Member
    TRD SPORT
  6. Apr 18, 2016 at 2:24 PM
    #526
    ExtraExtra
    ExtraExtra Well-Known Member
    Scott
    Toronto
    16 Tacoma TRD Sport / V6 auto / Black everywhere
    OEM hood guard, invisible 3m taped the headlights, tint to match, opt7 flux-beam headlights, opt7 Cree fogs, carista mods
    I just got these sent to Toronto, Ontario. Paid an extra $32 for customs/duty. Very easy install and I'm a goof with these things. Only need a long flat head screwdriver to pop clips. I got the flexbeam for headlights and Cree for the fogs. Unfortunately one of the fogs were damaged in shipping. Opt7 didn't protect them in any way, but I still blame USPS.
    Waiting to hear how to get a new one. I have 3 gorgeous lights on my truck! lol.
  7. Apr 23, 2016 at 6:29 AM
    #527
    Redfishcatcher15
    Redfishcatcher15 Well-Known Member
    2016 Sky Silver Tacoma Double Cab SR5 RWD
    I went with $32 Cree option I'm not so impress, because just running them they seem not as bright as the $99 headlight option. In fact when the headlights turned on it pretty much cancel out the fog lights beam. Is anyone having to same problem? Im thinking I should of purchase 3rd set on the $99 to put in the fog slots. :-(
  8. Apr 25, 2016 at 3:03 PM
    #528
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    anyone tried to change out the turn signals and tail lights to LED?
  9. Apr 25, 2016 at 3:08 PM
    #529
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    HutchJ and SilverII[QUOTED] like this.
  10. Apr 26, 2016 at 10:17 PM
    #530
    trdsport808
    trdsport808 Active Member
    Honolulu
    Mag gray tacoma sport
    Hey, I just purchased and installed the OPT7 headlights and fogs....
    Does anyone else have an issue where the DRL doesn't work unless the fogs are on?
    Also are your fogs much brighter than the low beam headlights?
  11. Apr 26, 2016 at 10:27 PM
    #531
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    No and no.
  12. Apr 27, 2016 at 6:22 PM
    #532
    GA_Taco
    GA_Taco Active Member
    Canton GA
    2015 Tacoma TRD Sport
    Anyone having issues with moisture in any of the housings? I installed HID's on my 2nd gen and had a moisture issue in the fog light housings. Hoping these won't be problematic on my 3rd gen
  13. Apr 27, 2016 at 6:27 PM
    #533
    T0ph
    T0ph Member
    Western MA
    Just installed mine tonight. Didn't follow the instructions and the lights didn't work. Need to be sure to use the adapter and follow instructions lol. Easy install and light quality is much better. Doesn't really seem like much more visibility but like the light quality, similar to my 15 STi I traded in.
  14. Apr 30, 2016 at 2:40 PM
    #534
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Hey guys, everyone doing pretty good with those so far? Car accident broke my HID's and I've been wanting to switch to LED anyways and I found these on Amazon.
  15. Apr 30, 2016 at 2:41 PM
    #535
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Also, do you guys know if these come in 5k? I'm afraid if I get 6k they'll be too blue. I want pure white.
    And are these Hi/Lo bulbs? I'm in a 1st gen so I need a hi lo bulb.
  16. May 1, 2016 at 8:46 AM
    #536
    Manta64
    Manta64 Well-Known Member
    Tony
    2016 Tacoma
    they worked ok? plug and play fog lamps?
  17. May 1, 2016 at 8:53 AM
    #537
    Manta64
    Tony
    2016 Tacoma
    Amazon says they do not fit my 16 taco? WTH !! please confirm =OPT7 LED Headlight Bulbs w/ Clear Arc-Beam Kit - H11 (H8, H9) - 60w 7,000Lm 6K Cool White CREE - 2 Yr Warranty
  18. May 1, 2016 at 8:56 AM
    #538
    Positronik
    Positronik Active Member
    Matthew
    Pittsburgh
    2016 Inferno SR5 4x4 V6 AC
    Weather tech mats, Clazzio seat covers, and STICKERS!!!
    Amazon has not updated the parts list for the 16's yet, so don't go by what the giant online bookstore says.
    tcBob, Scoobarooo and Manta64 like this.
  19. May 1, 2016 at 8:57 AM
    #539
    Manta64
    Tony
    2016 Tacoma
    so which ones are the right ones??? jut get this OPT7 LED Headlight Bulbs w/ Clear Arc-Beam Kit - H11 (H8, H9) - 60w 7,000Lm 6K Cool White CREE - 2 Yr Warranty
  20. May 1, 2016 at 9:09 AM
    #540
    Manta64
    Tony
    2016 Tacoma
