Just installed Opt7 LEDs in projectors and fogs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tasnowma, Jan 30, 2016.
  1. Sep 30, 2016 at 10:26 PM
    #841
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Oh man that looks awesome!!!
  2. Oct 1, 2016 at 8:17 PM
    #842
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
  3. Oct 2, 2016 at 12:53 AM
    #843
    Doc Hallows
    Doc Hallows Member
    2016 Toyota Tacoma TRD Off Road
  4. Oct 2, 2016 at 6:55 PM
    #844
    KB3
    KB3 Member
    2018 Inferno Tacoma DBLCB OR
    Ordered Opt7's. Fingers crossed I like em. Will let you know next week.
  5. Oct 2, 2016 at 7:32 PM
    #845
    ConnorBergmann
    ConnorBergmann Member
    Connor
    2016 Tacoma TRD Off-Road
    30" Bumper Mounted LightBar
    This might sound like a dumb question, but are the Opt7's high and low beams??
  6. Oct 2, 2016 at 7:56 PM
    #846
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    Low beam and high beams are separate on the 2016 . H11 for low and H9 for high.
  7. Oct 2, 2016 at 8:05 PM
    #847
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    wait don't H11's fit low high and fogs?
  8. Oct 2, 2016 at 8:06 PM
    #848
    Doc Hallows
    Doc Hallows Member
    Just lows and fogs I believe
  9. Oct 2, 2016 at 8:22 PM
    #849
    ConnorBergmann
    Connor
    So we would have to get the H9 and two sets of H11?
  10. Oct 2, 2016 at 8:33 PM
    #850
    Doc Hallows
    Doc Hallows Member
  11. Oct 2, 2016 at 11:12 PM
    #851
    Bajaxr201
    Bajaxr201 Well-Known Member
    Andrew
    San Diego, CA.
    2019 Off Road 4x4 DCSB
    |275/70R17 BFG KO2's | 17" Method NV Wheels| PRO Grille | CaliRaised LED bar and Ditch pods | LED interior Lighting |PlastiDipped emblems | WeatherTech Floor mats |
    no no no, many many people on here have said that H11 fit EVERYTHING.... lows, hi and fogs
  12. Oct 2, 2016 at 11:20 PM
    #852
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Yup, these LED units are not setup for projectors...
    iyapysnf[QUOTED] likes this.
  13. Oct 2, 2016 at 11:39 PM
    #853
    Doc Hallows
    Doc Hallows Member
    Oh. I don't know about that. I'm just going by what the manual says.
  14. Oct 3, 2016 at 12:14 AM
    #854
    ConnorBergmann
    Connor
    Final Consensus? My thought is, I'd just replace high and low beams, then replace fogs with rigid intiustries led cubes
  15. Oct 3, 2016 at 8:26 AM
    #855
    '16TacomaTRD
    '16TacomaTRD Well-Known Member
    2016 White Tacoma TRD Sport w/ premium tech & JBL package
    The H11 will fit both high and lows. It's shows it on their website
  16. Oct 3, 2016 at 11:49 AM
    #856
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    Thanks RNTaco for #331 and Tasnowma (OP)!!
    Just ordered the OPT7 H11 for Lows and OPT7 Fogs for fogs. Also ordered a bunch of the other LEDS.. Form the sticky LED thread!!
    Really appreciated the write ups and time you both spen on this.
  17. Oct 3, 2016 at 11:58 AM
    #857
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Not to shit on your thread but I also installed OPT7 LED low beams and fogs and wasn't impressed at all, but I've had properly retrofitted HIDs before so I've been spoiled.
    I just swapped them out for Philips 4300k HID low beams and Phillips 6000k LED fogs, MUCH BETTER. I'll try to take some comparison pics for everyone later but the Philips HID blows the OPT7 out of the water in regards to distance and light contrast with the road. The Philips fogs throw a much better pattern than the OPT7s and much wider and focused too, plust he OPT7 would just shoot light straight forward, wouldn't go far and just blind people. The Philips puts the light where you need it without straight up blinding oncoming traffic.
    Anyone considering this mod I promise you'll be much happier with Philips HID for low beams and Philips LED for fogs. Its twice the cost but worth the $.
    Edit: Here's the kit I got
    http://www.xenondepot.com/H11-automotive-bulbs-s/1047.htm
    LadyRed and gpb like this.
  18. Oct 3, 2016 at 12:21 PM
    #858
    imdav2u
    St. Louis
    If the hids have a longer distance you are probably blinding oncoming cars. The opt7 leds have the same cut off as oem so they don't bother oncoming traffic . The opt7 have a pure white that make oem bulbs look yellow. I didn't care for the opt7 lights the first 2 times that I drove at night but now I really like them. I don't know if it's an eye adjustment or if they get a little brighter after use.
    tasnowma[OP] likes this.
  19. Oct 3, 2016 at 12:44 PM
    #859
    Jaque8
    2017 Inferno TRD OR
    Actually the LEDs are FAR more blinding while at the same time being less effective at distance, especially in the fog lights. It doesn't have to do with cutoff as the HIDs have a very defined cutoff line as well, it has to do with Lux per watt where the HIDs are still far superior. LEDs require specialized housings to properly compound and project LED lighting at distance, without doing a full projector retrofit you simply cannot achieve that with LEDs. Its true HIDs should also have a proper retrofit to maximize efficiency but when both use a stock halogen projector the HIDs are less effected. But that's for low beams, since fog lights are more of a flood light and don't go the distance I stuck with Philips LEDs, even then they blow the OPT7 out of the water as they seem to have much higher quality optics (only explanation I can see for the vast difference in light diffusion and "blindingness").
    I have some night pics I can upload later but heres a pic while I was swapping out the OPT7 for Philips in the fog lights. Left is Philips, Right side is OPT7. You can see even in the daytime the OPT7 is just shooting light straight at you blinding. The Philips is much more subtle/focused and you can even see the reflector past the light. At night the OPT7 barely make it farther than 15-20ft ahead of me before light is totally diffused. The Philips go 2-3x as far and as you can see don't blind you while doing it...
    jonnyozero3 likes this.
  20. Oct 3, 2016 at 12:51 PM
    #860
    Leo4x2
    Leo
    San Antonio, Tx
    So HID's in the fogs instead of LED's?
