Just installed Opt7 LEDs in projectors and fogs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tasnowma, Jan 30, 2016.
  1. Feb 3, 2016 at 5:29 PM
    #101
    Brah Pitt
    Brah Pitt Active Member
    Johnny
    NJ
    Still have not installed, but a few pics.
    mindofhs3 and DeTako like this.
  2. Feb 3, 2016 at 5:40 PM
    #102
    CFTaco
    CFTaco Well-Known Member
    Central Florida
    3rd gen. Tacoma TRD Off-Road 4x4
    Shitty cell phone pictures but here you go:
    with fogs on
    DRHays10 likes this.
  3. Feb 3, 2016 at 5:41 PM
    #103
    Paint6it9black
    Paint6it9black Well-Known Member
    Rob
    Easton, Pennsylvania
    2011 Tacoma TRD Sport
    OME 3" lift in front Extended Kings in rear Dakar leaf pack Shackle Flip 1” body lift All-Pro front bumper All-Pro Apex rock sliders Kore 4x4 Custom HC rear bumper Window Tint 5% Mesh Grille (homertaco) Rigid Industries led fog lights Fog light anytime mod Rear Diff breather mod CB Radio Safari Snorkel Home Made tire carrier (not by me) 37's Cut, Bashed and Dented Freedom SS pillar lights Smittybilt x2o 10k winch synthetic U-Bolt Flip RCI Full Skids 2" cut off fenders Front and Rear ARB lockers Geared 4:88 On board air with 2-1/2 gallon tank Relocated cab mounts
    Love mine too!!
  4. Feb 3, 2016 at 6:27 PM
    #104
    DeTako
    DeTako Well-Known Member
    Felix
    Florida
    '16 TRD Sport 4x4 DCSB
    Thinking about pulling the trigger on these guys. Any concerns about heat? Burning/Melting plastic? Do LEDs get hot enough to be a problem?
    Thanks for all the pics. They look great!
    I plan to order all 3 sets(2xH11 & 1x H9) at once and just want to make sure things are good to go before I drop the $300.
    Brah Pitt likes this.
  5. Feb 3, 2016 at 6:28 PM
    #105
    TxAggie05
    TxAggie05 New Member
    2016 Silver Sky Metallic Tacoma Limited
    Got mine in and installed them tonight as well. Less than 15 minutes...and they look great! Haven't gotten to take them out on the road yet, but very impressed with them in the driveway.
  6. Feb 3, 2016 at 6:34 PM
    #106
    Paint6it9black
    Rob
    I've had mine in for a year and no problems whatsoever. Never gets hot.
    DeTako likes this.
  7. Feb 3, 2016 at 6:35 PM
    #107
    DeTako
    Felix
    Florida
    Thank you...
  8. Feb 3, 2016 at 6:39 PM
    #108
    tastethepoison
    tastethepoison Well-Known Member
    Kansas City
    2016 Inferno Sport 4x4 DCSB
    Halogen bulbs produce more heat than LEDs. The difference is the halogens can take the heat where the LEDs are more sensitive and require a built in fan or heat sink.
    Paint6it9black likes this.
  9. Feb 3, 2016 at 6:44 PM
    #109
    DeTako
    Felix
    Florida
    Makes sense now. I saw that a fan was required and I thought it was due to high temperatures. Thanks!
  10. Feb 3, 2016 at 7:58 PM
    #110
    DesertTRD
    DesertTRD Active Member
    3rd Gen Taco TRD OR
    Installed my low beams tonight. Look great!
    Paint6it9black and sunshinetaco like this.
  11. Feb 3, 2016 at 8:08 PM
    #111
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    Except the Limited they use the H16's in the fogs.
  12. Feb 3, 2016 at 8:36 PM
    #112
    sunshinetaco
    sunshinetaco Well-Known Member
    Ken
    CA
    2016 DCSB OR
    Ordered mine today!
  13. Feb 3, 2016 at 8:40 PM
    #113
    DesertTRD
    3rd Gen Taco TRD OR
    Had to turn off the fogs. The halogens look awful next to the LED low beams.
    sunshinetaco, mindofhs3 and Heepspo like this.
  14. Feb 3, 2016 at 8:53 PM
    #114
    TacoMEDIC
    TacoMEDIC Well-Known Member
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
  15. Feb 4, 2016 at 3:10 AM
    #115
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Are the ones you got in blue or just the picture shows it that way?
    Iroyal07 likes this.
  16. Feb 4, 2016 at 6:20 AM
    #116
    TopherWV
    TopherWV Well-Known Member
    Christopher
    OH
    16' DCLB OR Inferno
    Does the LED's have the same cast as the OEM's or is it a trade-off of purity and intensity? BTW, they look great and I will be pulling the trigger as well as long as the depth/cast is somewhat similar/acceptable.
  17. Feb 4, 2016 at 6:25 AM
    #117
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    To OP, you should do the fog light anytime mod. Make use of all your LEDs
  18. Feb 4, 2016 at 6:37 AM
    #118
    TacoMEDIC
    Matthew
    Apple Valley, CA
    2016 JKU Rubicon
    They're bright white. Just look blue in the picture.
  19. Feb 4, 2016 at 6:40 AM
    #119
    tasnowma
    tasnowma [OP] Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    You know I've been meaning to do that. I'll have I look it up. This allows you to use your brights and fogs simultaneously right? Thanks!
  20. Feb 4, 2016 at 6:52 AM
    #120
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    That is correct, not sure if anyone has anything for 3rd gen but lots for 2nd gen. Try it the 2nd gen way n be the guy to break ground on this mod if nobody has done it yet!? It also allows you to run only fog lights and DRLs. I'm watching for results. This is a very inexpressive if not free mod. I'm going to do this when I get my bumpers. Good luck!
