Just installed Toytec ultimate lift kit, I put the rear shim backwards, ?????
Discussion in 'Suspension' started by Jav S, Oct 28, 2010.
  1. Oct 28, 2010 at 11:46 AM
    Jav S
    Jav S [OP] Well-Known Member
    Montverde, Fl
    2010 DC TRD
    I noticed it after I already finished installing the kit. I wonder if I it will cause any big problems or do I have time to fix it later???????
    So far it rides good. need alignment and tires.
    Front both sides 38 1/4" and rears both sides 39 1/4 " fender to ground.
    [​IMG][​IMG]
  2. Oct 28, 2010 at 11:50 AM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    You should fix that as soon as possible. Probably won't do any real damage, but they are there to help correct your driveline angles. Did you do both sides the same way?
  3. Oct 28, 2010 at 11:56 AM
    Jav S
    Montverde, Fl
    2010 DC TRD
    Both sides same way, thin side facing to the rear.
  4. Oct 28, 2010 at 12:27 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    looking at your pics, it took a few attempts to see what you're talking about (I ain't gonna lie) - mainly because I was looking at the shortest leaf... are they supposed to bow down like that?
    (try to control your laughter)
    I did a RevTek 3" lift with AAL on my '96 a few years back, and after it was all done I realized I had one arching upward and one arching downward. Drove it like that for probably a year. It's fixed now, but I think I have mine both pointing up...
    Is that right?
    I apologize for the threadjack, BTW. :pray:
  5. Oct 28, 2010 at 12:29 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Looks to me like you've got it facing the correct direction. Check the "bjmoose installs OME" suspension link in my sig for details about why I think that and how to measure.
  6. Oct 28, 2010 at 12:55 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    It is indeed installed backwards. I would swap that ASAP. it shouldn't cause any damage but your pinion angle is gonna be worse than if you had no shim and you'll probably have some vibrations
    -Dylan
  7. Oct 28, 2010 at 1:05 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm really curious as to why you guys recommend shimming a single cardan drive shaft so as to bring the flanges further from parallel.
    That is not what Dana (the driveshaft mfr for US built Tacomas) recommends for their driveshaft installations.
    http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
  8. Oct 28, 2010 at 1:17 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x10000000000000^^^^^^^^^^^^^^^^^^^
  9. Oct 28, 2010 at 1:27 PM
    Toytec Lifts
    Rocky Mountains
    when you lift the rear of the truck, you are putting the pinion at a greater angle. The shims help bring the angle back to stock. I didn't see in that article where it said not to shim the single carden shaft. Maybe i am just looking in the wrong spot?
  10. Oct 28, 2010 at 1:36 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Check page 5. The relevant section is: (CAPS is theirs, not mine.)
    RULE 1: UNIVERSAL JOINT OPERATING ANGLES AT EACH END OF A DRIVESHAFT SHOULD ALWAYS BE AT LEAST 1 DEGREE.
    RULE 2: UNIVERSAL JOINT OPERATING ANGLES ON EACH END OF A DRIVESHAFT SHOULD ALWAYS BE EQUAL WITHIN 1 DEGREE
    OF EACH OTHER....
    RULE 3: FOR VIRTUAL VIBRATION FREE PERFORMANCE, UNIVERSAL JOINT OPERATING ANGLES SHOULD NOT BE LARGER
    THAN 3 DEGREES. IF THEY ARE, MAKE SURE THEY DO NOT EXCEED THE MAXIMUM RECOMMENDED ANGLES.
    A universal joint operating angle is the angle that occurs at each end of a driveshaft when the output shaft of the transmission and
    driveshaft and the input shaft of the axle and driveshaft are not in line. (See Fig 1)
    So, when you shim the pinion "fat side back" you're trying to fix Rule 3 "Keep the angles small" at the expense of violating rule 2 - that "the angles at each end should be within one degree of each other."
  11. Oct 28, 2010 at 3:00 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    To put it another way, shimming "fat side back" reduces or eliminates the pinion angle.
    Going with a zero/minimal pinion angle is the right configuration for a double-cardan (CV) driveshaft, as seen in this link to Tom Woods' custom driveshaft site:
    http://www.4xshaft.com/double_cardan.html
    But that's not the right configuration for a single cardan driveshaft.
    lpfe42 likes this.
  12. Oct 28, 2010 at 3:16 PM
    Toytec Lifts
    Rocky Mountains
    That is true. however, installing the shim does reduce/eliminate the vibrations caused by increasing the pinion angle.
  13. Oct 28, 2010 at 9:02 PM
    Jav S
    Montverde, Fl
    2010 DC TRD
    Thanks to all for the input. For a Truck rookie like myself I learn some.
    I will fix it tomorrow morning as Toytec recommend in all it is a Toytec Ultimate lift so I should do what they recommend on their product (I did not use the Taco today didn't want to risk anything).
    This was my first time installing a lift kit on a truck, so I kinda overlooked the direction of the shims.
    It was a straight forward install that it took me about 3.5 hours total front and back.
    Tomorrow I will be getting some 285-70-17 prob BFG AT TKO.
  14. Oct 29, 2010 at 1:24 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    May I suggest that you drive it first and see if you have any vibrations before spending more hours in the garage changing things?
    If you have no vibrations, there's no need to change anything, as the only reason to install, position, or change shims is to eliminate driveline vibrations.
  15. Oct 29, 2010 at 2:02 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    no biggie looks great just loosen swap direction and re tourqe then beer time:D
  16. Oct 29, 2010 at 4:20 PM
    Jav S
    Montverde, Fl
    2010 DC TRD
    OK, Udate............fixed the shims, got some BFG AT KO 285-70-17, and Aligement.
    What do you guys think?????
  17. Oct 29, 2010 at 4:24 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
  18. Oct 29, 2010 at 4:26 PM
    RMTacoguy30
    RMTacoguy30 Well-Known Member
    Jay
    Murrells Inlet, SC
    10 DC Prerunner Sport TRD
    EGR in channel Vent Visors, Flowmaster American Thunder Dual Exhaust, Thule ToolBox, AFE Pro Dry Drop In Air Filter, Weathertech Floorliners, TC UCA's, Camburg Spindles, AllPro 3" rear.
    Looks good man... Congrats on getting done... Now on to the next mod... lol
  19. Oct 29, 2010 at 4:26 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Looks good to me, but looking at that first pic, one thing you might want to do is install a longer brake line. Looks like it is stretched out a little too much. Maybe just me?? Truck looks good though!:D
  20. Oct 29, 2010 at 4:27 PM
    BlueXenon
    BlueXenon Well-Known Member
    Los Angeles and Newport Coast
    2024 Solar Octane TRD Sport (current) 2022 Lunar Rock TRD Sport (SOLD) 2020 Cement TRD sport (SOLD) 2009 Magnetic gray TRD sport (SOLD) 2004 Radiant Red TRD Off Road (SOLD)
    Looks great! Tires really made a difference!
