just installed
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma92, Aug 21, 2010.
  1. Aug 21, 2010 at 6:31 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    I finally installed my new headlight. Its working but it it a little loose compared to the other light. How do i keep it from moving around? Ive tried to see if i could tighten it but i dont know where to
  2. Aug 21, 2010 at 6:32 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    your headlight is loose? what do you mean by loose? did you screw all the screws back in?
  3. Aug 21, 2010 at 6:56 PM
    tacoma92
    Forrest
    yea i screwd them all back in but the light can be moved up and down a little bit. I kno it wont b able to come out, but when i hit a bump, the light will shake up and down a little
  4. Aug 21, 2010 at 7:23 PM
    tacoma92
    Forrest
  5. Aug 21, 2010 at 7:29 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    There's like a bolt and 2 nuts holding on the light. Not sure how you could screw that up. I would redo it and make sure everything is tight and no clips are broken.
  6. Aug 21, 2010 at 7:33 PM
    tacoma92
    Forrest
    idk how either. i screwd everything in tight like the previous light. mayb i just need to prop somethin up in there to keep it still :D
  7. Aug 21, 2010 at 7:38 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Is there an adjustment screw at the top for adjusting the angle of the light?
  8. Aug 21, 2010 at 7:40 PM
    tacoma92
    Forrest
    its at the bottom right of the light im pretty sure
  9. Aug 21, 2010 at 7:42 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Ya. I would wedge a woodchip up in the bottom. That should hold it.
  10. Aug 21, 2010 at 7:46 PM
    tacoma92
    Forrest
    yea thts prob the best way. my friend suggested that when he saw it too
  11. Aug 21, 2010 at 8:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Almost sounds as if the replacement housing isn't quite the right size. Is it OEM or aftermarket?
  12. Aug 21, 2010 at 10:23 PM
    tacoma92
    Forrest
    Its OEM
  13. Aug 22, 2010 at 8:46 PM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    lets see them new headlights!
  14. Aug 22, 2010 at 10:46 PM
    tacoma92
    Forrest
    Ill post some pics up tomorrow of the new headlight. Right now its pitch black dark outside :/
  15. Aug 26, 2010 at 8:29 AM
    tacoma92
    Forrest
    heres the new headlight on the right side
  16. Aug 26, 2010 at 8:37 AM
    CopDoctor
    Trinidad, CO
    looks good :)
  17. Aug 26, 2010 at 8:39 AM
    tacoma92
    Forrest
    thanks man. notice that im missing my front emblem :(
  18. Aug 26, 2010 at 8:39 AM
    CopDoctor
    Trinidad, CO
    didn't catch that at first, thought you just painted it black. some young guns snatch it from you??
  19. Aug 26, 2010 at 8:52 AM
    tacoma92
    Forrest
    i have no idea. either that or it came off somehow. Ive been lookin everywhere to buy a replacement for pretty cheap but no luck
  20. Aug 26, 2010 at 8:26 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Sealed beam FTW!!
