Just joined TW, stuck in the desert, and missing my truck!
Discussion in 'New Members' started by Justin626, Sep 28, 2007.
  1. Sep 28, 2007 at 11:33 PM
    Justin626
    Justin626 [OP] Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Hello all,
    I joined TW a couple of days ago and I'm already finding alot of good info. Bought my Tacoma about 6 months ago, but only drove for about the first three. Unfortunately I'm stuck on a deployment until early Jan. Before I left I was able to throw on a bull bar and some light force lights. Damn those are cool lights! My second Toyota, but my first new one. My first was an '88 Supra Turbo. It was a little run down.
    Right now I am looking into a 3" Toytec lift and probably tires somewhere around 33's. Any pointers or suggestions would be great. I would like to stick with the stock 17" rims, but not sure how well that is going to work out with the larger tires. And I've pretty much decided to go with blocks instead of AAL in the back. See everyone around the forums.
    Justin
  2. Sep 29, 2007 at 12:24 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Ditch the blocks, they will give you a lot of axle wrap and prematurely sag your rear leaf packs. I would say go with AALs or shackles for the rear.
  3. Sep 29, 2007 at 6:51 PM
    Justin626
    Palmer, Alaska
    Hey humanoid
    Thanks for the pointer. The main reason I had pretty much decided to go that route was because Toytec suggested it. I was also going to get the center bearing drop kit. Would that help alleviate that problem?
  4. Sep 29, 2007 at 7:20 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Welcome to TW Justin. I think I would go crazy if I had just purchased my truck and then I had to quit driving it for several months. Bummer!
  5. Sep 29, 2007 at 8:11 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i ordered mine while i was in the desert last year....sucked pretty bad too...lol
  6. Sep 29, 2007 at 10:25 PM
    scard
    scard Active Member
    El Centro, CA
    2001 Toyota Tacoma PreRunner Total Chaos UCA's with Donahue Racing Coilovers
    Magnaflow Exhaust, Total Chaos Upper Control Arms with Donahue Racing Coilovers, Bilstien Shocks in the rear.
    I just put some on the gallery section, enjoy.
  7. Sep 30, 2007 at 12:03 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I'm unsure about the center bearing drop for a 3" lift, I'm guessing you won't need one, but don't quote me on that. What problem are you having or trying to avoid with the bearing drop?
  8. Sep 30, 2007 at 7:02 AM
    Justin626
    Palmer, Alaska
    Thanks rhoppas and jhodge......I can't wait to get back. I'm getting ready to miss it's first snow season.:mad:
    Thanks for sticking with me humanoid. I've heard that when adding a lift kit it usually causes vibration in the driveline caused by the increased angle. I guess maybe I should have called it a carrier bearing instead of a center bearing.
    Do you have any experience with front diff. drop kits?
    Thanks again,
    Justin
  9. Sep 30, 2007 at 8:23 AM
    TacoChef
    TacoChef Well-Known Member
    I did have some vibration after installing my TuffCountry 3" lift. There was nothing in the instructions so I called TuffCountry. They said to lower the carrier bearing w/ shims until it was better. I did and it worked. I have just a slight vibration now at initial start. Before it had carried through 35 mph. Now that is gone. I guess you have to give and take w/ some of these mods.
  10. Sep 30, 2007 at 8:46 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    AFAIK, you won't need a diff drop for the 3" lift, but there are differing opinions on this so I'll let the more knowledgeable ones chime in on this.
  11. Sep 30, 2007 at 8:41 PM
    Justin626
    Palmer, Alaska
    Sweet! Thanks humanoid and TacoChef. I'm feeling pretty straight on what set up I should get. Now I just need to get home so I can atleast drive it.
  12. Oct 1, 2007 at 12:00 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Stay safe and come home in one piece!
  13. Oct 1, 2007 at 8:57 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Welcome to the forum and stay safe!
  14. Oct 2, 2007 at 4:01 PM
    Justin626
    Palmer, Alaska
    Well, luckily my location is relatively safe.
