Just left the stealership and now i have a question?
Discussion in 'Technical Chat' started by 05tacoSPORT, Oct 7, 2010.
  1. Oct 7, 2010 at 5:56 PM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    So i took the truck by Toyota and they serviced the tranny, Replaced the seals in the front diff, fixed the turbo sound with a new idler pulley and put in a new power steering rack and pinion/with tie rod ends. My question is should the alignment done again?
  2. Oct 7, 2010 at 6:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    do you have the lifetime one from firestone?
    I would just get it done since you replaced all those worn parts and that probably moved things around.
  3. Oct 7, 2010 at 6:07 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    NOPE I WILL HAVE TO PAY FOR IT \ /
  4. Oct 7, 2010 at 6:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    I would get one anyways. Worn steering part replaced with new- Chances are stuff isn't lined up the same any more...Did you check the paperwork to make sure they didn't do one already??
  5. Oct 7, 2010 at 6:19 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    no i didn't. Most was under warranty and it was a pain in the butt to get them to do the work they did.
  6. Oct 7, 2010 at 6:20 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They didnt do one? or at least offer to do one? Thats kind of a no brainer on their part...
  7. Oct 7, 2010 at 6:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Do you have the paperwork?? That the place to start. If they did not- The lifetime deal from Friestone has done good by me!!
  8. Oct 7, 2010 at 6:24 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    How much is the firestone lifetime alignment And i will check the paperwork asap
  9. Oct 7, 2010 at 6:27 PM
    Brunes
    Brunes abides.
    Rotorhead
    I got mine for about 135. It's lifetime you own the truck, as often as you want. I took mine in about 4 times in a month when I did my lift.
  10. Oct 7, 2010 at 6:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I have it too and intend on using it with every tire rotation. I had them do it twice in the first month after the lift and they got the caster pretty good for having stock UCA's. I think its totally worth it.
  11. Oct 7, 2010 at 7:14 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I wish they had that up here. Gets pretty rough at $50-$100 a pop.
  12. Oct 7, 2010 at 8:19 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    They most likely re-aligned your truck.
    If they didnt, you would have probably noticed your steering wheel slightly off center.
