Just Letting you KNOW!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by manrdz01, Jan 17, 2009.
  1. Jan 17, 2009 at 11:10 AM
    manrdz01
    manrdz01 [OP] Member
    South Tx
    Tacoma
    :confused: At one point I thought I had gotten all the details about the 05 Tacoma and its frt bearings? Well, Simple! NOT! U don't even use a socket 35mm nor 63mm totally off! Tanx for the note though? Just letting you know you do need special tools for the baby!;) This is for those that are coming up 60K miles!
  2. Jan 18, 2009 at 2:55 PM
    nighthawk87
    nighthawk87 Well-Known Member
    What the......
  3. Jan 18, 2009 at 3:36 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Must be off his medication?
  4. Jan 18, 2009 at 3:39 PM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
  5. Jan 18, 2009 at 4:40 PM
    manrdz01
    South Tx
    Tacoma
    Hello, I was only replying to the information i got awhile bak on how to remove the front bearings on my 05 Tacoma! I didn't get the best reply but I was very tanxful for the advise! If you need n e information on It I can help now since I repaired them on my own with the help of some resources at Frank's Smith Toyota in Pharr, Texas
  6. Jan 18, 2009 at 4:42 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    how do you do it.
  7. Jan 19, 2009 at 11:00 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    you can replace the bearings w/o taking off the axle nut?
  8. Jan 24, 2009 at 4:34 PM
    manrdz01
    South Tx
    Tacoma
    ! Well after removing the hub off the spindle you need to press out the bearing! After figuring out that it does need a special press to remove the hub that is were Franksmith Toyota came in they have a new digital press machine that works perfect for that type of hub bearing? Believe me I did my studing around this particular hub style! It takes a particular psi which is input as if it were a cpu to pull out that hub from the bearing and on top of this you need that special tool to remove in the back, round nut off the hub threads before you start doing any work removing the hub! Also such spending rough estimate to spend on this job about/around $700 bucks if you don't do it yourself
  9. Jan 24, 2009 at 6:08 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    wow, thats pretty expensive. how much are the actual bearings themselves? like 200 bucks?
  10. Jan 24, 2009 at 7:56 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    off topic and shit but what part of south texas are you from? the brownsville area or what?
  11. Jan 28, 2009 at 12:57 PM
    manrdz01
    South Tx
    Tacoma
    That is Mission/McAllen area down in south Texas!
  12. Jan 28, 2009 at 1:10 PM
    manrdz01
    South Tx
    Tacoma
    Has n e 1 done any major work on their Tacomas! Lets hear about them?
    Well I live about 1hr15min away from Brownsville! Will be opening up a Automotive repair shop pretty soon around March here in Mission Tx! Will be trying all makes and models! Would have love just stickin to Toyotas and off roading but its all about making the money!
  13. Jan 28, 2009 at 1:14 PM
    TEX357
    TEX357 TX
    05 TACOMA
    ohhh i live about 140 miles from mission
  14. Jan 28, 2009 at 1:14 PM
    manrdz01
    South Tx
    Tacoma
    At or around that range of $'s! But let me tell you there are other ways of getting out that bearing my thing was the delicate-C of the system since it was my first time! Fairly simple when you have the right tool! Now who says you can't use Mexican inginuity!
  15. Jan 28, 2009 at 1:19 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Reading through this thread has convinced me that it was written by some teenage girl text-messaging posts from her phone.
    Sorry for the derailment. :)
  16. Jan 28, 2009 at 3:32 PM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    Ganja.....
