Just lifted but kant get rid of the small shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clankey, Mar 31, 2010.
  1. Mar 31, 2010 at 11:56 AM
    clankey
    clankey [OP] Well-Known Member
    St. John's, NL
    2010 Double Cab TRD Sport
    Roof Rack, Soft Tonneau, Running Boards, DDM HID's, Skid Plate, 3" lift, 275/70R17 BFG AT TA's
    Ok
    I have a 2010 double cab long box automatic TRD Sport and I installed the Tuff Country 3" lift kit with rear leaf.
    I hve a small shudder form 10KPH to about 25kph. I tried the 1/4 shim for the carrier bearing but it was actually worse. Anyone have any other solutions they could tell me.
    Thanks everyone!
  2. Mar 31, 2010 at 12:27 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    did you shim the rear diff?
  3. Mar 31, 2010 at 12:29 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Do you feel it more in the seat or the steering wheel?
  4. Mar 31, 2010 at 12:29 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Mar 31, 2010 at 12:30 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i have roughly the same thing after installing my 4" spindles, bils at 0.85 and OME leafs. im going to try a leafpack angle shim as mentioned above....but let us know when you get it worked out!
  6. Mar 31, 2010 at 12:37 PM
    clankey
    St. John's, NL
    No did not
  7. Mar 31, 2010 at 12:38 PM
    clankey
    St. John's, NL
    More in the seat. NOthing in the steering wheel.
  8. Mar 31, 2010 at 12:41 PM
    clankey
    St. John's, NL
    What is and where do I get the rear axle shims?
  9. Mar 31, 2010 at 12:41 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I would get the axle shims and try that. Try it with the bearing drop and without. See if there is an improvement either way.
  10. Mar 31, 2010 at 12:43 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  11. Mar 31, 2010 at 12:49 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ do i need a new center bolt for my OME leafpack if i was to install hte shims? want to ensure that they still engage in my axle and wont slip off!!
  12. Mar 31, 2010 at 12:52 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I don't think so.
  13. Mar 31, 2010 at 1:02 PM
    nvdeserted
    Reno, NV
    Probably driveline then. I don't know much about the bearing drop but I know that shims directly address the angle of the driveline, I've had to do that a couple times before on other rigs and had immediate success.
    Also, did you get new tires at the same time? I once had some joker improperly balance my rear tires and it felt just like driveline issues but not until 50mph.
  14. Mar 31, 2010 at 1:04 PM
    nvdeserted
    Reno, NV
    No, you just 'thread' the center bolt right through the shim, it has a hole in it.
    Depending on how long your U-bolts are you can usually just loosen them enough to get the pin out of the leaf perch and tap the shim in with a hammer. Then retighten/align the pin into the leafperch and torque nuts= done.
  15. Mar 31, 2010 at 1:25 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ cool, thanks dude. so just to confirm, the shim will become part of the pack (its basically like a washer on a bolt setup.)
  16. Mar 31, 2010 at 6:39 PM
    nvdeserted
    Reno, NV
    No, the shim will not be attached to the pack. it just sits between the pack and the leaf perch and the centering pin just slides through it like a peg. No need to loosen or remove the centering pin.
