Just making sure these lift parts will work before I spend the money.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gainman, Jul 5, 2010.
  1. Jul 5, 2010 at 4:53 PM
    gainman
    gainman [OP] Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Hey everyone,
    Immersed myself in information and searching on here about lifts and I have a list of what I am going to get. I just want to make sure I am not screwing something up and spending money I do not need to spend so give me the ok please!
    -5100s all around
    -OME 885
    -1.5" aal
    -Wheelers Offroad Steelies 16x8 black with 4" backspacing (going for a little wider look)
    -265/75-16 BFG km2
    Now for a couple quick questions:
    1- I will run the 5100s at 0 with the 885 springs correct?
    2- Will the 1.5" aal make the rear level or do I need the 2"?
    3- I know its a big debate and everyone is different, but the build I have seen with the wheels I want he runs 285s. Can I get away with that? I dont do any serious offroading (for lack of spots to do so).
    Am I missing anything? Should I add anything? Diff drop maybe?
    Thanks for the help, there is so much info with the search info its a little overwhelming so I want to make sure I got it right before I do it.
    Dominik
  2. Jul 5, 2010 at 4:54 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    The 285's should fit, you will need to trim a bit of the inner wheel well.
  3. Jul 5, 2010 at 4:58 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    For the km2s it's alot of the inner liner but still worth it
  4. Jul 5, 2010 at 4:58 PM
    gainman
    SW Florida
    Stuff
    you are talking about the plastic well lining? what is that on your truck in your sig? are those 285s?
  5. Jul 5, 2010 at 4:59 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    The front 5100's arent recommended with the 885's or 886's due to shock valving. The shocks are built to handle the weaker factory springs, so there may be some dampening quirks running the 5100's and 885's together. I'd get the OME front shocks built to handle the springs.
    As for the rear, it depends on how much lift you get out of the 885's. It seems to vary from what I have seen of them. Mine were an old set and netted 1.75" of lift, however some guys get like 3 1/2" somehow. If you want the most lift possible in the front (dont go over 3" by much!!), you'll want some OME 1/2" top spacers and stud kit for the front, and the 2" aal for the rear to match. Maybe even the 1 1/2" aal, along with a 1" block depending on what you want the truck to look like, and if you regularly haul stuff in the back.
    285's should fit easy with a little trimming and removal of the mud flaps.
  6. Jul 5, 2010 at 4:59 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    -yes, I also ran a 1/2" spacer
    -do you have the rear TSB done, if so then the 1.5 will work otherwise go with the 2"
    -yes, you will have to to do lots of trimming, I was not able to run them until I put the spacer on, it is physically 1/2" wide and give about 3/4"-1" of lift. My 885s only gave me about 2.5"-2.75" of lift and the 285s rubbed like crazy, once I put the spacer in I was at 3.25" and the 285s only rubbed while flexing and turning
  7. Jul 5, 2010 at 5:00 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Yeah, all I had to trim was a little plastic with a pocket knife. I was about to go snap a pic but forgot the truck is gone r.i.p., LOL.
  8. Jul 5, 2010 at 5:01 PM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    With the 4 in B/S you'll rub more when turning. I would go with the 4.5".
  9. Jul 5, 2010 at 5:44 PM
    gainman
    SW Florida
    Stuff
    Do you have a link or can you tell me which spacer helped you out? I do not have the TSB done although my dealership told me they will do it if I want. I think ill just go with the 2".
  10. Jul 5, 2010 at 5:46 PM
    ktmrider
    Junk
    I currently have 1.5 inches of lift on my 885s. I believe its from the supercharger weight
  11. Jul 5, 2010 at 10:16 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    check out toyteclifts.com
  12. Jul 19, 2010 at 9:17 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    I guess so
