Just my luck!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Oct 29, 2010.
  1. Oct 29, 2010 at 10:52 AM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    So i am taking my truck to an offroad shop near my house to get my new CV boots on and when i got off the freeway my truck just died. I can start it and run the truck with my foot on the gas but i cant keep it idling, or else it just completely shuts off. i checked for loose vacuum hoses and battery connections but i have no idea why it would do this so randomly. Any ideas?
  2. Oct 29, 2010 at 11:48 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    Hmm thats tough..maybe an electrical problem
  3. Oct 29, 2010 at 11:53 AM
    1998tacoma4x4
    Orange County
    idk i was thinking the IAC or the throttle body. No idea though it was so random. Off topic but ive seen your truck at SCC haha.
  4. Oct 29, 2010 at 12:20 PM
    ERIC
    Eric
    Orange County, CA
    Yea i have no idea it could be a number of things but that is wierd! No way you go to SCC too?
  5. Oct 29, 2010 at 12:32 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Fuel filter? How many miles on the 98',no engine light? Codes
  6. Oct 29, 2010 at 2:18 PM
    TGurau
    TGurau Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    Same thing happened to me because i over used seafoam. Have you recently done seafoam treatments? Maybe the spark plugs are fowled. Pull one out and check it, if it's black, change them all. I used the NGK iridiums and they're spendy but awesome, helps with mpg too.
  7. Oct 29, 2010 at 2:30 PM
    1998tacoma4x4
    Orange County
    fuel filter just changed maybe 250 or 300 miles ago.
  8. Oct 29, 2010 at 2:30 PM
    1998tacoma4x4
    Orange County
    no i have never seafoamed but i did try cleaning the throttle body about a week ago.
  9. Oct 29, 2010 at 2:31 PM
    1998tacoma4x4
    Orange County
    sorry i also have 101100 miles
  10. Oct 29, 2010 at 2:31 PM
    1998tacoma4x4
    Orange County
    ya ive met you before through your buddy anthony with the white mazda haha
  11. Oct 29, 2010 at 7:39 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    it has something to do with gas...think about it the truck will only stay on if it give it gas, if you let off the truck dies...check for loose plug. i.e.:mass air flow, tps, map sensor...
    also check to see if your getting enough fuel pressure, if not enough pressure, fuel pump could be bad
    does your truck rev up just fine when you gas it to keep it from shutting off or does it putters and struggle?
  12. Oct 29, 2010 at 7:41 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    sounds like the mass air flow sensor or more probably the idle air control valve
  13. Oct 29, 2010 at 11:53 PM
    1998tacoma4x4
    Orange County
    Ya the truck revs up fine and will drive fine too it just wont idle when i stop..
  14. Oct 29, 2010 at 11:55 PM
    1998tacoma4x4
    Orange County
    Thats what i was thinking too. How hard is it to replace the IAC?
  15. Oct 30, 2010 at 12:02 AM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Check the air filter box back to the throttle body, My dads truck started acting like that one time and then it died completely and would not start at all. Come to find out the hose from the air filter had come off.
  16. Oct 30, 2010 at 12:04 AM
    1998tacoma4x4
    Orange County
    Ya i checked all the vacuum hoses and stuff like that so idk, but thanks for the input anyways!
  17. Oct 30, 2010 at 4:19 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    check your efi relay. swap it out with the abs relay or similar in the fuse box and see if it works. my truck had the same issue at one time it sounds like. just throwing that out there, I believe it is electrical though. hope that helps.
  18. Oct 30, 2010 at 5:09 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    IAC really isnt too bad, you have to take off the throttle body to get to it though, and if i recall correctly its a toyota only part. if you go there and ask for a labor manual they may give it to you
  19. Oct 30, 2010 at 7:34 AM
    Mush Mouse
    mush
    2013 SR5
    I was thinking fuel problem also,but if it was the pump they usually just quit not linger on,no matter how you pump the gas pedal,thats how mine went out just died would not start or idle at all.
  20. Oct 30, 2010 at 8:23 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    this probably isn't it, but when u cleaned ur throttle body did u maybe adjust ur idle control screw, & not realize it?
