Just needed a jump start, will my truck start back up tomorrow?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drjohnson36, Sep 13, 2011.
  1. Sep 13, 2011 at 9:53 PM
    drjohnson36
    drjohnson36 [OP] Well-Known Member
    09 Pre-Runner SR5 DC
    I just had to get a jump start from a coworker to get home. I didn't leave my lights on, my truck is an 09 purchased exactly 2 years, 3 months, and 7 days ago. I still have the OEM battery. I have work again tomorrow at 5am, do you guys think my truck will start up in 7 hours? Or should I just borrow my gf's car?
  2. Sep 13, 2011 at 9:57 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    It SHOULD start right up, my other truck dies every so often and i mean dead dead dead no even crank, i jump it and let it run for like 5-10 mins turn it off and its good to go. But i would check latter on tonight to see if it starts before you sleep so you can know if you need to barrow your g/f`s car
  3. Sep 13, 2011 at 10:01 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Check it in the middle of tonight
  4. Sep 13, 2011 at 10:52 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    No it wont. You have to blood let a small child on the engine and then stuff kitten in the tail pipes and it should start right up.
    If not then I will buy if from you for 1 cup of coffee and the the change in my sofa.
  5. Sep 13, 2011 at 10:58 PM
    Tigahshark
    Isaac
    :eek:
  6. Sep 14, 2011 at 6:28 AM
    drjohnson36
    I ended up taking the gf's car. I'm gonna stop by the dealer this afternoon. Does the OEM battery fall under the 3yr/36k warranty? Or is it considered a preventative maintenance item?
  7. Sep 14, 2011 at 6:58 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The freshest batteries are available at.....wait for it......Walmart; I guess because they sell so many of them.
  8. Sep 14, 2011 at 7:02 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Your warranty should cover it but they will have to see it acting up. Make them load test it. Chances are it may be fine but like said before once they start acting up its usually just a matter of time. I had my battery replaced under warranty after 3yrs.
  9. Sep 14, 2011 at 7:39 AM
    drjohnson36
    Sweet thanks. My local dealer has generally been nice with warranty and TSB's, so hopefully they'll come through with this
  10. Sep 14, 2011 at 7:48 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    This exact same thing just happened to me a week ago. Oem battery only lasted 2 years. My mileage just fell under warranty. Dealer said it was covered and replaced battery with new. Should do the same for you.
  11. Sep 14, 2011 at 9:04 AM
    saugus
    saugus Well-Known Member
    Might have a leak especially if you installed a radio or something. 2 year old oem battery should not die this fast. Mine is 6 years old and still cranks fine. I would check voltage while off and while on. Then check it again tomorrow and compare any voltage drops. But if dealer will replace it then even better.
  12. Sep 14, 2011 at 9:06 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Had this happen to me about a year ago on my 09. Took it to the dealer and they replaced it for free
  13. Sep 14, 2011 at 9:08 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    You should be fine. Unless the battery was completely drained (which you wouldn't have been able to jump), than it should be okay. It won't hurt if they will replace it, but no need to buy a new one.
    Amendment: If you do have trouble starting than it is probably not the battery that is the issue.
  14. Sep 14, 2011 at 9:10 AM
    Blackshirts
    TX
    Stuff
    Mine would take a jump and start right up. Had to do it twice took it to dealer and they changed out the battery and have not had the issue again.
