Just noticed I still have my 24 year old spare tire still underneath.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kevin Jones, Mar 2, 2020.
  1. Mar 2, 2020 at 8:25 AM
    Kevin Jones
    Kevin Jones [OP] Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Just noticed my original Dunlop spare tire is still mounted (un-used) under my '96 4x4 Tacama.
    I wonder what kind of mileage I could still get out of it? ;)
    I've never had a flat tire in 24 years/414,000 miles so never had a reason to use it.
  2. Mar 2, 2020 at 8:57 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I think that tire has reached its "best if used by" date. :)
    Perhaps the spare tire winch, too. You've seen the recall that was issued on those, yes?
    [Oops -- the recall was only on Gen 1.5 trucks. See @jammer's details below.]
  3. Mar 2, 2020 at 9:04 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That thing is probably hard as a rock.
    My spare (2004) is original as well, also never used. Next time I get new tires, I'm definitely getting 5.
    Kevin Jones[OP] and Hamer95USA like this.
  4. Mar 2, 2020 at 9:12 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    24 years is a good streak of no flats! i've had just one so far in 23 yrs, but noticed it in the driveway one morning so just jacked up the truck and took it for repair
    just put some tire wet gloss on it and it will look good as new :cool:
    my truck originally came with goodyear wranglers not dunlops, i wonder why?
  5. Mar 2, 2020 at 9:12 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I was about to say you could probably get that rusted tire carrier replaced but then I noticed yours is a '96 :(
  6. Mar 2, 2020 at 9:15 AM
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    As to not having a flat in 24 years, good for you. Knock on wood though :D
  7. Mar 2, 2020 at 9:59 AM
    jbrandt
    Justin
    Or just run E rated tires... ;)
  8. Mar 2, 2020 at 10:59 AM
    Kevin Jones
    Kevin
    Va
    Didn't seem hard, but tire pressure is real low.
  9. Mar 2, 2020 at 11:03 AM
    Kevin Jones
    Kevin
    Va
    I didn't really notice how rusted the tire carrier wing was until seeing the photo. The shock covers (original shocks) are very rusted as well, but frame is in amazing shape.
    I need to remove the spare, check it out and address the carrier.
    GQ7227 and jammer[QUOTED] like this.
  10. Mar 2, 2020 at 11:07 AM
    Kevin Jones
    Kevin
    Va
    You were probably better off with the Goodyear as I remember the original Dunlops not lasting very long at all. Other than the original factory set, I've always gotten very good tire mileage with this truck.
    GQ7227[QUOTED] likes this.
  11. Mar 2, 2020 at 11:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    my trucks mileage dropped real bad when i changed from the stock wranglers to the duratracs, it is still unclear where 2 to 3 MPGs went!!
    the only thing i can really do is to buy another set of wheels (refinished) and different tires then troubleshoot if there is a big difference in mileage
  12. Mar 2, 2020 at 11:11 AM
    Kevin Jones
    Kevin
    Va
    Need to knock on wood every day as this truck has never given me any issue tires or other wise, been an amazing truck.
  13. Mar 2, 2020 at 11:16 AM
    eon_blue
    Azusa, CA
    I've torn a sidewall on an E rated tire :anonymous:
    Granted 1 flat in countless wheeling trips over 3.5 years is a pretty good record if you ask me, I definitely think E rated is the way to go if you wheel. Overkill on these trucks for sure but worth the peace of mind when you're in a remote area
    pray4surf likes this.
  14. Mar 2, 2020 at 11:57 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I had the GoodYears too and it's my original spare under there. I thought it was a TRD thing to have them as they were 31x10.50s. I'm also of the persuasion that while E's are way over kill, I too never had a flat and running over a gafftop catfish was usually a sure thing.
    Kevin Jones[OP] and GQ7227 like this.
  15. Mar 2, 2020 at 1:17 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    Last week when rotating my tires I also checked on my 20 year old, never touched pavement, spare.
    It never gets in the rotation because the truck came with factory aluminum wheels and the spare is standard steel wheel.
    I can’t see buying new but I am keeping my eyes open for a newer used tire to replace it.
  16. Mar 2, 2020 at 9:14 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    Fairly rust free, too! You must not be in the salt belt.
  17. Mar 8, 2020 at 11:09 AM
    SteveW504
    SteveW504 Active Member
    '96 4WD
    Body lift by previous owner. Rear welded locker by same fool.
    That tire is probably brittle, but if it's only used as a spare at slow speeds, could serve you for a short ride. Best to replace it. ...at least you still have yours. Last year as I was heading down the mountain roads to town I saw a tire on the side of the road, and said out loud, "some idiot threw a tire out". Someone else did pick it up before I headed back home, so I was glad. A week or so later as I went to change my differential fluids, I found that the cable holding the spare in place had snapped, and I was the idiot. The replacement lives in the bed under the camper shell.
  18. Mar 8, 2020 at 1:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @Kevin Jones , Maybe a Tire Museum would be interested in your spare. When I purchased my 03 DC back in 2010, it also had the original spare, never used, but I didn't use it, and bought a new tire when I purchased my first new set.
    GQ7227 and Kevin Jones[OP] like this.
  19. Mar 8, 2020 at 2:06 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    which is more 'museum quality', dunlop or goodYear :stirthepot:
  20. Mar 8, 2020 at 7:06 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
