Just noticed.... no chirp on keyless lock.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kingfrog, Jan 17, 2011.
  1. Jan 17, 2011 at 9:12 AM
    Kingfrog
    Kingfrog [OP] Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Did the previous owner disable this or did I just get lucky?
    I am not used to a vehicle that doesn't chirp or sound the horn on the second press of the remote to lock the vehicle.
  2. Jan 17, 2011 at 9:13 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Standard.
  3. Jan 17, 2011 at 9:14 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Mine has never made a sound
  4. Jan 17, 2011 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Jan 17, 2011 at 9:15 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I know for sure my 06' doesnt chirp. I think they started adding that in 08.' :rolleyes:
    ToyoTaco25 likes this.
  6. Jan 17, 2011 at 9:29 AM
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    My '10 chirps onces on lock, twice on unlock.
  7. Jan 17, 2011 at 9:32 AM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    same for my 11
  8. Jan 17, 2011 at 9:39 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    You can turn the chirp on and off - if you search around on the site wither in 2nd gen or tech discussion I think there are a couple of threads on the subject
  9. Jan 17, 2011 at 9:47 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i as well have the chirp on my '11.
    i have attached the page from the '11 manual describing that the dealer can silence the chirp.
  10. Jan 17, 2011 at 9:54 AM
    jkcb2011
    jkcb2011 Well-Known Member
    Eastern Ontario, Canada
    2011 TRD Sport 4x4
    I had the locking/unlocking beep, as well as the chime for the seatbelt. But, due to the outstanding info on this site I found, I created a document that outlines how to remove them both. This worked for my 2011 DC TRD Sport.
    Disable seat belt chime - Tacoma
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    ENABLE OR DISABLE DOOR LOCK BEEP CHIME
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT: The driver side door is closed.
  11. Jan 17, 2011 at 12:52 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    A quick and easy method is to just remove the "chirper" ..... up by the battery.
    Taped off harness end ....
  12. Jan 17, 2011 at 1:03 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    the chirp is standard on all toyotas with keyless entry (over 50% of the cars here are toyotas and its a cacophony of chirps everywhere). It is defeated physically or by turning it off.. combination of holding trip button and turning on car in a certain fashion.
  13. Jan 17, 2011 at 1:16 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    I have an 06 and never had a chirp but my horn does honk when I lock the doors. I also found out my battery took a crap when it stopped honking
  14. Jan 17, 2011 at 1:52 PM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    My '06 never chirped and I was happy about that. Just got an Avital alarm and it chirps, but I guess the point is that lurking thieves know you are arming the vehicle.
  15. Jan 17, 2011 at 1:56 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    haha i have an avital also ... one nice thing is if you dont want to chirp it, (in my case when i go to get another beer after the girl is asleep), you just hit the trunk button then the lock / unlock.
  16. Feb 8, 2011 at 2:53 PM
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    Thank you!
    I just confirmed this to work on my '11 AC Sport
    No more annoying beep at unholy hours (or any hours)
    hresendiz25 likes this.
  17. May 7, 2011 at 6:00 PM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    My 05 doesn't chirp either. But I do have the oem alarm. It's the VIP one and the blinking red light and glass sensor is in the middle blank underneath all the top buttons. Can someone confirm if am able to turn on a chirp?
  18. May 8, 2011 at 7:45 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    05 thru 09(?) do not chirp with lock/unlock. That feature was added in later models.
    I have an 08 and it did not have the "chirp" feature. I added a Peizo buzzer to make mine chirp when I lock it. There's a DYI mod thread in here somewhere. You can get the buzzer at Radio Shack for about $10. The mod should only take about 20 minutes.
  19. May 8, 2011 at 8:12 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    When I click the lock/unlock button on the key chain clicker there is a beep/chirp. I found the little lock/unlock chirper under the hood and put a piece of black electrical tape over the speaker hole and it still chirps just not very loud like before. It was just a little loud for my taste before but now is much better :)
  20. May 8, 2011 at 8:43 AM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    My 08 doesn't chirp :cool:
