just order my billys!
Discussion in 'Suspension' started by KaliTaco, Oct 6, 2008.
  1. Oct 6, 2008 at 11:09 AM
    KaliTaco
    KaliTaco [OP] Well-Known Member
    well i just got the front billys from dsm. then im getting my rear tsb for my 08 done on wednesday. after that im looking to getting 1 inch blocks for the rear. with the tsb it should go up 1 inch in rear. i have a dc lb so it should be around 1/2 inch to 3.4 inch lift after settle right? so 1 inch block plus tsb. so 1 1/2 to 1 3/4 lift with stock shocks will that be ok?
  2. Oct 6, 2008 at 11:30 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you arent gonna be offroading/flexing the suspension alot...stock rears should be ok. if you dont feel like they are safe, you may be able to get some rear shock extenders, but again, they may not be needed. i think on a set of bilstein 5100 rear shocks, they are good for up to 2 inches of rear lift, so that may be something to think about also. just food for thought!:)
