just ordered lift..now what tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtmccray, Feb 16, 2012.
  1. Feb 16, 2012 at 4:25 PM
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Just ordered front 0-3.5" bilstein coilovers, chromoly uca's, diff drop and rear 3" springs, now I gotta figure out what size tires to run. Thinking 33/12.50ish but not sure. Anybody else running this? What size tires are you using?
  2. Feb 16, 2012 at 5:18 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Return the diff drop, it is crap and doesn't help anything at all. Run the 33's just like about 500000000000000000 members are doing the same.
  3. Feb 16, 2012 at 5:19 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    You're going to get a ton of different answers on tires.
  4. Feb 16, 2012 at 5:24 PM
    dtmccray
    millbrook alabama
    01 money pit
    So a 33/12.50 size tire will clear more or less? On factory rims? Or do I need to get some something with different spacing? Diff drop doesn't cost enough to worry with canceling. You dont think it helps with your cv angles? Why not?
  5. Feb 16, 2012 at 5:25 PM
    dtmccray
    millbrook alabama
    01 money pit
    Yeah I dont need brand/style opinions just what will and won't clear.
  6. Feb 16, 2012 at 5:27 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    If you want to run a tire that wide im guessing you need different wheels.
  7. Feb 16, 2012 at 5:27 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    depends how high you go on the coilovers. 285's are most commonly run with under a 6" setup
  8. Feb 16, 2012 at 5:29 PM
    dtmccray
    millbrook alabama
    01 money pit
    3" on the coilovers...unless I need that other.5.
  9. Feb 16, 2012 at 5:33 PM
    dtmccray
    millbrook alabama
    01 money pit
    Any oddball stuff that I'm going to need to do? extend abs wires? brake lines for the front?
  10. Feb 16, 2012 at 5:35 PM
    Supra TT
    Eric
    Indiana
    You aren't changing any amount of travel in the suspension for the front, no need to worry about brake lines. Possibly in the rear you will, but doubt it.
    As far as the diff drop, it just rotates the diff thus not dropping it at all really and making it sit lower to the ground. You got a lift, why ruin it by lowering the components you are lifting? Makes no sense.
  11. Feb 17, 2012 at 3:33 AM
    dtmccray
    millbrook alabama
    01 money pit
    Anybody running a 305/70r16? It comes out to 32.8x12. If so what backspacing? Any issues with it?
  12. Feb 19, 2012 at 1:30 PM
    dtmccray
    millbrook alabama
    01 money pit
    Would I come out better using a 17" rim or stay with a 16? I'm thinking 8-9" wide with 4-4.25 bs that should clear everything shouldnt it? I have been searching but cant seem to find the information im looking for. Any info would be appreciated. Thanks
  13. Feb 19, 2012 at 1:50 PM
    Supra TT
    Eric
    Indiana
    Go with a 16" rim, tires tend to be cheaper at that size.
