Just ordered my 5100's and have a question
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Jan 22, 2011.
  1. Jan 22, 2011 at 3:49 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    so i just ordered my bilsteins 5100's my question is, is that do you think i should replace anything else on the front end like bushings or upper control arms? and where would i order new bushings?
  2. Jan 22, 2011 at 3:51 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    may not be a bad idea since your truck is a little older. You can buy new Bushings and UCAs for Toyteclifts.com
    Here's a link
  3. Jan 22, 2011 at 4:00 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    i dont need a diff drop kit do i? or would that also be a good idea?
  4. Jan 23, 2011 at 10:41 AM
    NickJ*97756
    NickJ*97756 Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
    I have bilsteins set at 2.5" and didn't need a diff drop. My cv angles are perfect
  5. Jan 23, 2011 at 10:43 AM
    ColtsTRD
    Scott
    AZ
    No, you'll be just fine ;)
  6. Jan 23, 2011 at 12:19 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Don't worry about UCA's.. Unless you are a hardcore wheeler. And if you are.. 2.5" Isn't much to worry about with these trucks.. I beat the shit out of mine for 2 years with 3" spacers and bilsteins after.
  7. Jan 23, 2011 at 3:20 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    it takes a fair amount of beatings but im not into wheeling, just tearin' shit up
  8. Jan 23, 2011 at 3:55 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    these bushings pretty cheap? and where do i find them, ebay?
  9. Jan 24, 2011 at 1:58 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
  10. Jan 24, 2011 at 4:18 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    it may be time replace your steering rack bushings and sway bar bushings theyre probably pretty worn out by now and are a relatively cheap mod. both are available from or directly from http://www.energysuspensionparts.com
  11. Jan 25, 2011 at 8:49 PM
    98Tacoma
    98Tacoma Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    i would put a front diff drop i have a pretty good angle on the cvs then i installed the front diff drop and i could tell a big difference looking at them. also i did have vibes before i installed the diff drop and stopped after. i had the bilsteins set at 2.5
  12. Jan 25, 2011 at 9:07 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    I just got them in today, im not sure how im going to set them i dont have the tools. i was reading on a different thred for 2nd gen and someone took their shocks to midas to get them adjusted
  13. Jan 26, 2011 at 2:13 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    yea they have will probly have a nice spring compressor. or you could rent one from ur local auto parts store but you need to be very careful while doing that tho
  14. Jan 26, 2011 at 2:37 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    i just contacted down south motorsports which is where i bought them from and they said you can adjust these billy's just by moving the ring in the middle to the three different grooves on the sides of the shock? if this is true then why cant you just adjust them yourselves?
  15. Jan 26, 2011 at 2:56 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    yea thats all you have to do is move the perch and the little snap ring. but you have to compress the spring so that you can put the top hat that pushes down on the spring so that it can bolt down.
  16. Jan 26, 2011 at 3:06 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    You can get the bushings from your local Toyota dealer too. If you get them from toytec, they come out to be about the same price after shipping.
  17. Jan 26, 2011 at 3:49 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    well yes but you actually can set the shocks pretty easy, just makes it harder to put the spring in?
  18. Jan 26, 2011 at 3:51 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i went with the energy suspension ones i am pleased
  19. Jan 26, 2011 at 7:39 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    mine came set at 2.5 it is pretty hard to compress the spring to get it to fit i had to put 4 of the hand held compressors to compress the springs enough its a crazy amount of pressure
  20. Jan 26, 2011 at 8:23 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    this is some pictures of the bilsteins i got, im pretty sure they are set at the highest setting (2.5") but not sure..... input would be appreciated :)
