just ordered new UCA's! any tips?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quast, Oct 18, 2010.
  1. Oct 18, 2010 at 6:52 PM
    Quast
    Quast [OP] Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    I just ordered some light racing uca's and was wondering if anyone has some tips for the insatll or tools that I may need that are outside of regular hand tools? any input is greatly appreciated.
  2. Oct 18, 2010 at 8:28 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    very nice, let us know how the install goes, if you dont mind how much did you pay for them and where did you get them from?
  3. Oct 18, 2010 at 8:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  4. Oct 18, 2010 at 8:41 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Install is pretty straightforward. Just be sure to secure the spindle after you remove the ball joint so it doesn't flop around and thrash the brake lines.
    Oh, and be careful around any fuel and data lines in the vicinity while you do your thing.
    Matter of fact, just be gentle with all lines you encounter. Other than that, it's just bolts and a little plier work.
  5. Oct 18, 2010 at 8:45 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i just installed mine the other day, i got some replacement bolts from the dealer ship so the install would go smoother, if not, your going to have to bend the inside part of the fender to get the bolt out and there are some lines in the way, you will find out if you chose to do it, its a pain but it can be done. why toyota put these in this way is just plain dumb. i helped another member with pulling these out and let me tell you the 22 bucks for new bolts are well worth it. to make things easier another person would be nice. i did some coilovers and LR uca's and it took me six hours. < taking my time
  6. Oct 18, 2010 at 8:48 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    throw em on and enjoy!:D
  7. Oct 18, 2010 at 9:33 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
  8. Oct 19, 2010 at 3:43 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    a radio and some cold beer:D also another set of hands is nice when trying to get the foot long bolt fed back through the new UCA. youll have to bend the inner wheel well a bit to get it out,then gettin it back in it needs to line up with washers and bushings so another set of hands is definitly helpful. also a torque wrench will be needed if you dont already have one.
  9. Oct 19, 2010 at 9:17 PM
    Quast
    Dustin
    Mission, BC
    i paid 540 i think with shipping and i got them from kamloops bc at baja north. just easier for me since im in canada dont want the hassle with the border and buying local is good thing too.
    so if i were to just gfet new bolts would i still have to bend the fender in order to get the new bolt in?
    thanks for all the help guys and ill be sure to have some brews and a radio going along with a few helpers who are in it for the beer ahah.
  10. Oct 19, 2010 at 9:22 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, TRD skid plate, light pods mounted in front bumper
    Mine come in tomorrow :)
  11. Oct 19, 2010 at 11:24 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    On my 02, which should be pretty much exactly as your 03, except I dont have the ABS wire to deal with, I didn't have any real issues with the UCA bolt. I did have to take off the air bag sensor because it was in the way, and I choose to remove the air box and battery for a little more room, but I didn't have to bend anything. It was tight and had to be wiggled in a little, but nothing close to needing to bend anything for.
    As far as extra tools, your upper ball joint is going to be on tight (not the bolt/nut, but being seated in the knuckle and UCA). I recommend renting a ball joint press to remove it. Dont skimp with a cheap one as you really need to put some pressure on to get that ball joint to pop out. I dont know if you have Checkers there, but that is where I rented my press from (Looked like a heavy duty C-Clamp). Also, I got tired of fussing with both ends of the ball joint when I really didn't care about the old UCA, so I just cut the ball joint in half with a saws-all. Makes it a bit easier to deal with two halves instead of the whole.
    An impact wrench helps as well, as always.
  12. Oct 20, 2010 at 5:03 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i will second the motion on using a BJ press,that wouldve made life easier when i did mine but i wasnt able to find one.ended up doing the same as Manlaan;cuting it with a sawzall and beating it out.
  13. Oct 20, 2010 at 6:35 PM
    Quast
    Dustin
    Mission, BC
    yeah to get it out i have a pickle fork to get the old uca apart from the spindle.
  14. Oct 20, 2010 at 7:13 PM
    907taco
    Bobby
    Alaska
    you won't have to bend any metal if you cut the bolt out, just loosen enough to get a saw blade in there, i used a saws all with 6 in. blade, just watch out for the alternator on passenger side and the drivers side is clear mostly. i have a 2.7, drivers side the bolt is just long enough to seem its too long, remember you want to put the new bolts in from the rear of truck to front, i had to get around 4 i want to say fuel line but not sure, i had to bend the bolt towards the engine and tap the bolt past these. As far as removing stock uca from spindle arm i just hammered it out of there, my truck is fairly new so its not like it was rusted or hard to remove. best of luck but i have very litlle mechanical skills and did this myself so as far as i am concerned anyone can do it.
