just picked up a 1999 reg cab 2.7 4x4...
Discussion in '1st Gen. Tacomas (1995-2004)' started by ateel7, Aug 9, 2022.
  1. Aug 9, 2022 at 11:07 AM
    ateel7
    ateel7 [OP] New Member
    with 131k. in great shape, minimal rust. changed oil, air filter. what else would you recommend? thinking of coolant flush and plugs and wires.
    is zerex asian pink okay? and recs on wires and plugs.
    thanks
  2. Aug 9, 2022 at 11:12 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    make a YouTube video, walking around, underneath, inside the cap and under the hood, while the engine is running.
    then, we can tell you what it may need...
  3. Aug 9, 2022 at 12:09 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Brake fluid flush, change oil in Transmission (MT), Tcase, front and rear differentials. Replace vacuum hoses with thick wall silicone hoses.
    Buy the kit online from Silicone intakes.com
    cruxofthebisquit and Abeyancer like this.
  4. Aug 9, 2022 at 9:41 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    yes the pink stuff is what toyota recommends. I think that should be it. Check your trans fluid too. Same with differential. Plugs would be what the owners manual recommends. I'd go with the longer lasting iridium ones just so you won't have to change them as often
  5. Aug 9, 2022 at 9:46 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Sell that garbage to me so you don't have to deal with it.
