Just picked up this 1995 Tacoma/hilux?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CONMAN1, Oct 19, 2018.
  1. Oct 19, 2018 at 6:11 PM
    CONMAN1
    CONMAN1 [OP] New Member
    1995 Toyota Tacoma/Hilux
    My first Toyota truck. Has 180k miles. Frame is rust free, body has rust but this will be my Minnesota winter daily driver. Just here looking for advice on what kinda stuff I should do to get her running reliably. The guy I got it from was great and had done tons of work. Is it the Hilux or Tacoma? It's got a V6 ,auto trans and 4x4.
  2. Oct 19, 2018 at 6:17 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum.
    Sharp looking 1st gen. Congrats.
    CONMAN1[OP] likes this.
  3. Oct 19, 2018 at 6:21 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You have a beauty there, but it is a model prior to the launch of the Tacoma. Some call the first year Tacoma "1995.5" due to the launch timing. The model change significantly changed the look of the entire truck.
    Here is a picture of one of mine, which is also known as a 1995 model, but this is a Tacoma.
  4. Oct 19, 2018 at 6:22 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Very nice, it brings back memories....and welcome!
  5. Oct 19, 2018 at 6:22 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    It's a hilux
    cruxofthebisquit and CONMAN1[OP] like this.
  6. Oct 19, 2018 at 6:24 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup, thats just a "Toyota Truck" in North America nothing wrong with that.
    Biggest thing is start by making sure all the fluids are clean and topped off.
    Those engines have timing belts and they should be replaced around 7 years or 100,000 miles. Sometimes the repair shop will leave a sticker to indicate when it was performed last. If the belt breaks, the cam and crank will spin free of each other causing a no start.
  7. Oct 19, 2018 at 6:26 PM
    Wsidr1
    Indiana
    As far as winterization, check battery strength (Autozone/O'Reilly's can do it), check coolant ratio, 4 wheel drive function, consider treating the underbody with POR-15 and/or Fluid Film, and put on some A/T tires.
    Edit: BTW, I'd kill for those vent(wing) windows. Those things were so great on the older cars and trucks. I don't like driving with AC except on long 55mph + trips.
  8. Oct 19, 2018 at 7:32 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    You're 0/2...Not a Tacoma and not a Hilux.
    It's a "Pickup" but that doesn't mean it's bad. Those trucks are pretty great too, just different than Tacoma and Hilux models. There are some parts compatible with two (or all three) models, but still good to know what truck you have when you go to find parts for it.
    Riding Dirty and CONMAN1[OP] like this.
  9. Oct 19, 2018 at 9:22 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Unless he bought it in europe or Australia, it's not a hilux.
    It's a Pickup. I know, super glamorous name, but Toyota didn't actually give the US pickups a "name" until the 1995.5 Tacoma. I believe this is a 95 Pickup. Not a Tacoma
  10. Oct 19, 2018 at 9:23 PM
    jbrandt
    Justin
    Believe that's a 3.0L V6, too, which means the head gaskets are notoriously bad. Make sure those have been replaced
  11. Oct 20, 2018 at 6:07 AM
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    Thankfully the 3.0 wasn’t continued in the Tacoma line.
  12. Oct 20, 2018 at 7:58 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Hilux/truck/ pre-Tacoma works. Great basic truck, wish they still made a version. Head gaskets are biggest watch point. Enjoy your 'beater' that may become your adopted child.
  13. Oct 20, 2018 at 9:58 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Someone correct me if I am wrong but I think that is a 1994, not a 1995. 1994 was the only year that had the raised rear brake light like that on the cab. I remember because I had one. They did it for 1 year only and then stopped.
  14. Oct 20, 2018 at 3:18 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    If it's going to be your winter beater and you want to make it reliable, first thing you want to do is rustproof (or fluid film if you want to DIY) your frame (if it's not too badly rusted already)
    Only takes a few years of exposure to winter salt and chemicals to turn a frame into swiss cheese and have the truck end up like this:
  15. Oct 20, 2018 at 4:57 PM
    CONMAN1
    Hey awesome thanks for the info. Timing belt was just done, and new battery. I'm getting new tires for it and will look into the head gasket and rust proofing the frame.
  16. Oct 20, 2018 at 5:04 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Welcome to tw. As a fellow minnesotian Dont drive it in the winter u will destroy it. Its a beutiful Tacoma. Unless its a early 95 than its a pickup. I got a 93.
  17. Oct 23, 2018 at 6:22 AM
    CONMAN1
    I'm going to rust proof the frame best I can. It's super clean besides the body rust. Got some new tires to start things off!
  18. Oct 23, 2018 at 6:44 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Corrosion X spray can:thumbsup:
  19. Oct 23, 2018 at 6:56 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    3.0 and the 3.4 essentially share the same block. Head design was changed and I've heard of the bhg issue on the 3.0's as well. Look into this and you'll never have a frame rust issue:
  20. Oct 23, 2018 at 7:01 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
