Just Purchased '05 Tacoma, New to Toyota Clan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bisch7, Jan 29, 2015.
  1. Jan 29, 2015 at 3:58 AM
    bisch7
    bisch7 [OP] New Member
    MD
    Base
    just trying to keep it running
    So i just bought a 1005 Tacoma, I have never owned a Toyota before, I have owned the only one car ever and that was a 2002 VW Jetta 1.9L TDi. The Tacoma has 102k on it currently and I was wondering what should I be looking out for with these cars, also what should my check list be as far as maintenance checks?
  2. Jan 29, 2015 at 4:00 AM
    Large
    Large Red
    Welcome from Houston.
    There is an owner's manual in the glove box, but if there isn't you should check for frame rust first off. Second it says you have a base reg cab, and I'm not sure but you might need to replace the spark plugs and the enginge coolant. It might be different than the 4.0 but I'm not 100% sure.
    Good luck.
  3. Jan 29, 2015 at 4:03 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    You drove a vw jetta, but your gender says male?
  4. Jan 29, 2015 at 4:40 AM
    bisch7
    MD
    Base
    Sure did...221k miles, its the Turbo Diesel model, sadly when I was younger I drove that thing into the dirt. I got the Tacoma so I have a car I can use as daily driver while I slowly piece the Emerald Monster back together. At 55mpg it was very hard to let that thing go.
  5. Jan 29, 2015 at 4:43 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Low miles for a 2005.
  6. Jan 29, 2015 at 4:58 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Congrats. I would change the fluids they haven't already been. This is a good site to get a lot of useful info to whatever you are going to use your Rig. Welcome and congrats.
  7. Jan 29, 2015 at 5:30 AM
    Toeb
    Toeb Well-Known Member
    Toby
    Nc
    Trd off road
    Spc uca and leveling kit, 17" drop star 645 265/70/17, n fab step rails.
    welcome to TW!!! youll find the folks here are very helpful.
  8. Jan 29, 2015 at 10:27 AM
    molimelight
    molimelight Well-Known Member
    MO
    14' Pyrite Mica TRD Sport 4X4
    Congrats on your purchase! The first thing I would do is inspect the frame and see if there is any rust through. Toyota did a Limited Service Campaign on 05 through 08 frames on the Tacomas that were operated in certain states. NY qualifies if that's where you are. You can go on the Toyota Customer site and register with the VIN of your truck and you will be able to see the LSC and the details if it qualifies. It ends 03//31/2016 so you could look and see and if it doesn't look bad, put off the frame inspection at the dealership until closer to the end date of the LSC. Because if you take it in and it doesn't pass, they deem it unsafe and won't let you drive it off the lot. They'll give you a loaner and they will replace the frame on your truck. A great deal, but you often have to buy ancillary parts that you will probably want to replace before they put it back together, shocks, bushings, etc. I've heard the parts can run up to $500 or so, but it's worth it because they don't charge labor. Just do a search of 2nd Gen Toyotas on this board for "2005 Frame Rust" and you'll get more than you will ever want to read. Good luck and post photos when you can.
