Just purchased Light Racing UCA
Discussion in 'Suspension' started by ToyoTaco02, Jul 18, 2012.
  1. Jul 18, 2012 at 7:24 PM
    ToyoTaco02
    ToyoTaco02 [OP] Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Finally got tired of my low caster. Hopefully these will improve upon my 1.4 caster.
    Question for anyone with these. When I install these and set the caster on the arms to 2* will it push my tire into the rear fender? Anyone experiencing any squeaking with the new specride bushings. Thanks
  2. Jul 19, 2012 at 9:31 AM
    DevL
    DevL Well-Known Member
    Yes it will... the point of LR is so you can add 1 deg caster and move wheel less rearward.
  3. Jul 19, 2012 at 9:48 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    After I installed mine it was night and day with how stable my steering was. It was a little squirly on the highway with my stock UCA's. The light racing arms have a lot of adjustability, just hopefully you find a competent tech who does your allignment. The tech at the shop could not understand that my aftermarket UCA's had extra adjustment.
  4. Jul 19, 2012 at 10:20 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    I'm in the middle of installing mine on my 1st gen. Have a question. I am going to set them at the "zero" setting (+2 degrees caster), but I am not sure where to set the camber setting. Havent seen anybody talk about this so I'm wondering if it's a relatively new addition to the LR uca's. Should I just eye ball it to get me to the alignment shop? Explaining to those tards is going to be fun...
  5. Jul 19, 2012 at 10:43 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Most guys just pull the ball joint all the way out. Buddy and I put a level on mine. Wasn't much difference to be honest (was moved in maybe 1/8" inch?). I got a 2nd gen though. Not sure if there is a difference.
  6. Jul 19, 2012 at 12:13 PM
    NegroTundra
    Land of Enchantment
    Hmmm, yeah they must be different because I can pull/push mine in/out about 1" plus or minus. Guess I'll just pull it all the way out and try to talk with the alignment tech. Thanks for chiming in.
  7. Jul 19, 2012 at 12:17 PM
    JonnyBb
    Arkansas
    Sorry, I wasn't clear. Mine has the same amount of adjustment. I just meant that I only pushed the ball joint in about an 1/8" from all the way out to get the wheel vertically level.
  8. Jul 19, 2012 at 12:54 PM
    NegroTundra
    Land of Enchantment
    10-4!
