Just replaced my battery.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nolagrip, Sep 1, 2015.
  1. Sep 1, 2015 at 3:23 PM
    nolagrip
    nolagrip [OP] Member
    Ted
    Metairie, Louisiana
    05 prerunner
    So, I put in a new battery and now my truck does not want to stay running. Low idle at stops and quits. Do I need to reset anything?
  2. Sep 1, 2015 at 3:59 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    The ecu needs to relearn after it looses voltage. It shouldn't be stalling though.
  3. Sep 1, 2015 at 4:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    My Jeep did the same thing, it just took a couple minutes of just keeping my foot on the gas to hold it around 1000+ RPM and then the ecu figured it out and was fine. Different vehicle, but likely same scenario. The Jeep would stall initially as well.
  4. Sep 2, 2015 at 2:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Take it out and drive it for a few miles. The ECU was reset when you had the battery out.
