Just sanded and fluid filmed my frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Mar 13, 2014.
  1. Mar 13, 2014 at 9:07 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Just spent 3 hours under my truck. I panicked a bit because a few flakes the size of a toonie came off in a few places exposing orange rust on the frame. Good news is it sanded down to bare metal real quick. All in all I think my frame looks good. Three cans of fluid film and she is done until mid summer. I will probably sand it again before winter and then reapply fluid film.
  2. Mar 13, 2014 at 10:41 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Is there a reason you don't want to paint THEN fluid film? I wouldn't leave the metal exposed like that - fluid film or not.
    I bet only 30-40% of people on here even know what a toonie is. Lol
  3. Mar 14, 2014 at 6:16 AM
    rhowell
    Robert
    Canada
    Good call. I was thinking about it. I will wait until summer and then spot sand it down again and paint it.
  4. Mar 14, 2014 at 6:22 AM
    DecaturTide
    DecaturTide Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    Hey, what's a toonie?
  5. Mar 14, 2014 at 6:35 AM
    rhowell
    Robert
    Canada
    A two dollar coin about twice the size of a quarter. Funny.
  6. Mar 14, 2014 at 6:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You're going to have a hard time getting paint to stick to it now that it's been oiled up. Make sure you clean it really well and good luck!
  7. Mar 14, 2014 at 10:54 AM
    rhowell
    Robert
    Canada
    Yeah I was thinking that too. Well I only sanded the two or three spots and a couple of the welds so If I decided to paint it it would be easy. That being said I think I am just going to leave it and continue with the twice a year fluid film treatments. Like I said I think my frame seems really good when compared to what others have posted on these forums. Those three spots were sanded down to bare metal in 60 seconds each and I just have minor rusting on some of the welds.
    Sometimes I worry about covering up the problem because then you can tell what going on.
  8. Mar 14, 2014 at 11:14 AM
    happy
    happy Well-Known Member
    Eagle, CO
    '14 DCSB SR5 4x4 Silver Sky
    CBI Moab 2.0, 2.5" Radflo Coilovers, Light Racing UCA, Dakar Leaf Pack, 265/75 16 Kelly Safari TSR, Leer XR100
    A toonie--fascinating--learn something new everyday :rolleyes:
  9. Mar 14, 2014 at 11:28 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I put mine up on ramps last night and even though I only have 1500 miles I could already see little rust spots starting out all over the place. I soaked the entire undercarriage with soap (generic auto wash for pressure washer stuff), then pressure washed it for about an hour to get every trace of road salt off. I went all out and got a new air compressor, a hot plate, a 1 gallon fluid film kit w/ pro spray gun, and 2 giant canvas drop cloths. From what I've read it sprays just fine at room temp but I figure a little hot water presoak will make everything mix, pour, and spray that much easier. Tonight I'll put it back up on the ramps and coat absolutely everything. I figure one treatment right now, another this fall, and then after that I'll just rinse it real good each spring and respray it each fall. I lost my first pickup to frame rust but that's not happening to this one!
  10. Mar 14, 2014 at 12:23 PM
    rhowell
    Robert
    Canada
    I will be treating mine in the spring and in the fall. Rust is normal but I intend to do what I can to control and slow down the rate at which mine rusts. On a seperate note. The Fluid Film was still clearly visible and thick in places where I was not able to pressure wash over the winter. So that means it lasted 6 months of Canadian winters and was still sticking to the frame. Good stuff.
  11. Mar 14, 2014 at 10:36 PM
    ssanders2211
    Midwest
    '14 DCLB 4x4
    Just got done, it probably took about 3-4 hrs. The 1 gal can of fluid film is way thicker than the aerosol stuff. About the same consistency as peanut butter if you warm it up in the microwave, yet it sprays pretty good. Getting a few aerosol cans will definitely be quicker, cheaper, and easier but I doubt it will stick as good as the heavy stuff.
    I have this air compressor:
    http://www.homedepot.com/p/Makita-4...l-Twin-Stack-Air-Compressor-MAC2400/202713485
    It got the the job done, but it's not quite up to the task. It probably takes about a half hour to fill up from empty, and I had to stop 3 times and wait 15-20 mins for it to catch up. The pro sprayer from Kellsport works at any PSI above 5 or 10 or so, but it makes a really nice spray at 60. To help my compressor keep up, I set my regulator at 20psi so I wouldn't have to stop as much. It didn't vaporize as well but the droplets still covered well and they were small so I figure they'll spread out over the next few weeks and cover the entire surface.
    The extension wand doesn't work at all at lower PSI but did just fine when I cranked it back up to 60. Extremely useful for getting into places you can't really see, or enclosed portions of frame. I'd recommend starting with this and then switching to the main nozzle after you're done. I would have saved a lot of time I spent trying to hit hard-to-reach places the first time around.
    For clearance, I drove up on top of 4 of the 8" rhino ramps. It was a little tight in some places but I was able to get the entire undercarriage.
    Going forward, I'm not going to use any soap down there anymore. My pressure washer is pretty weak so I think if I hit it real thoroughly every spring after the salt trucks are put away, it will clean the salt out without removing all the fluid film. Then I'll respray fluid film in the fall before it gets cold out and I think it will get 100% coverage down there over the years. Next project is to figure out how to get some of it inside my door and rocker panels.
  12. Mar 14, 2014 at 11:52 PM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Toonie: Too-nee; a canadian coin meaning (two) dollars, originated from the coin loonie (one dollar)
    That's what it's all aboot eh
  13. Mar 15, 2014 at 12:14 AM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    Am I the only one who had to google "fluid film"? Had never heard of it..
  14. Mar 15, 2014 at 12:16 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  15. Mar 15, 2014 at 6:45 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    If you're in Canada then I would go with Krown, applied yearly just before the first snowfall.
    Also, just so everyone else is tracking, the one dollar coin is called a 'Loonie' because there is a bird called a Loon on one side of it.
  16. Mar 15, 2014 at 6:52 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    No
  17. Mar 15, 2014 at 7:25 AM
    TheDuke0fHurl
    TheDuke0fHurl Well-Known Member
    Boston
    2013 DCLB SR5
    Those weird wacky Canadians.
  18. Mar 16, 2014 at 5:51 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Fluid film is awesome.
  19. Mar 16, 2014 at 6:05 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Glad we don't deal with this down here.
