just some lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fidgit07, Jan 31, 2017.
  1. Jan 31, 2017 at 4:56 PM
    Fidgit07
    Fidgit07 [OP] Well-Known Member
    David
    13 Taco TRD Off-road
    Rough country 3in suspension lift AMO Buckshot rims 285/75R16. -6 offset RC Bullbar
    I just installed a 3in lift with LR UCAs. tire size is 285-75r16. I have vibrations at highway speeds and I got the tires road force balanced, driveshaft modified for the angles and balanced...getting ready to install that needle gear upgrade bushing from ECSG.
    If the bushing doesn't fix the vibrations what will?
    Is there anything I can do about the CV and Tie-rod angles?
  2. Jan 31, 2017 at 6:57 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My advice would be to do the ECGS bushing and then report back. I'd bet that will take care of your problem, it did on mine.
  3. Jan 31, 2017 at 7:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Takes 1 minute diag the diff bearing.
    If it makes noise/vibes in 2WD but not 4WD its the bearing.
  4. Feb 1, 2017 at 2:12 AM
    Fidgit07
    David
    What if it still does it in 4wd? Any ideas?
  5. Feb 2, 2017 at 3:28 PM
    winkel
    Corydon, IN
    Why don't you check it first and see. I think most here think this is the first option for a reason.
