Just some suspension help
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRENTON86, Mar 11, 2015.
  1. Mar 13, 2015 at 7:15 AM
    TRENTON86
    TRENTON86 [OP] Active Member
    Trenton
    North, Idaho
    01 TRD SR5 LIGHTBAR
    Front bumper, toyos, lightbars, headache rack and tool box, hids, headlight covers, leveling kit, and stereo system.
    If I show you a pic of my truck on flat ground would that be better?
  2. Mar 13, 2015 at 7:45 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No need to go down that much unless you're still high in the rear. But you pretty much can't go over 2.5" in the front unless you have a drop bracket unless you want it to ride like shit and blow CV boots
  3. Mar 13, 2015 at 7:45 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Probably yes. Try to get a pic of the inner CV boot also.
  4. Mar 13, 2015 at 7:53 AM
    TRENTON86
    Trenton
    North, Idaho
    01 TRD SR5 LIGHTBAR
    Do I need to remove my differential drop kit Ehem I lower it?
  5. Mar 13, 2015 at 8:55 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Might as well keep it.
  6. Mar 13, 2015 at 10:14 AM
    TRENTON86
    Trenton
    North, Idaho
    01 TRD SR5 LIGHTBAR
    So pretty much I just should take out the blocks, then just level the truck and it will drive nicer and be more reliable
  7. Mar 13, 2015 at 5:04 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    How much rear lift do you have
  8. Mar 13, 2015 at 5:43 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Dude, I had basically the same problem as you w/ my toytec shocks. I just recently discovered what I was doing wrong. Adjust the shocks back to exactly how they came and don't adjust them any tighter. They come pre set maxed out. So if you want to level your front end out just loosen the shock to match the other side don't tighten it! It will be an extremely rough ride and you will ruin steering/suspension components if you keep it adjusted tighter than it originally came. I just found out my steering rack is done basically because of how I had my shocks set.
    I wouldn't be super concerned about the blocks if you can't afford an add a leaf right now, but I would highly suggest considering getting one eventually.
    Edit: what are the rear shocks you got???? You might be over extending them and that is why it's such a rough ride in the back end.
  9. Mar 14, 2015 at 11:20 AM
    ElTacoma
    ElTacoma Well-Known Member
    San Luis Obispo
    2011 tacoma wheels, spidertrax 1.5" lug-centric spacers, magnaflow exhaust, magnaflow cat
    good info. Also, I have shackles in the back. They make the ride really soft, but if you're not towing heavy stuff ( I tow a small trailer with two bikes max) you should be fine. I have my blisteins set at about 2.5" and OME 881's in the front. perfect for my little single cab
