Just throwing this idea out there
Discussion in 'Street Trucks' started by Gr8WhiteTaco, Jan 30, 2011.
  1. Jan 30, 2011 at 10:28 AM
    Gr8WhiteTaco
    Gr8WhiteTaco [OP] bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    but is it possible to lower a 4x4 DC 1st gen? I know you can take a DC body and swap it onto a 5 lug frame, but you lose the v6 and 4x4. I ain't seen anything on here or CT about it so just asking. Got my umbrella out for :crapstorm:
  2. Jan 30, 2011 at 10:35 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't think it's possible with pre-made kits. I know that I have seen people lower 4x4 chevy trucks and SUVs. But it seems more popular to modify those than a Tacoma. Plus they don't sit as high to start with, so you're only talking about a four inch lowering job.
    Might try calling every company you can find who makes lowering kits and ask them. If they do have a kit, it's probably not going to see a lot of advertising in magazines, online, etc.
    Lowered isn't my cup of tea, but it would sure be a headturner if you could pull it off.
  3. Jan 30, 2011 at 10:40 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Yeah. I haven't found much of anything. I like the idea of having a V6, 4wd w/ locker, seating for five, and a truck bed that sits and rides like a car. I wouldn't exactly wanna lay frame on bags just because that sounds intimidating to pull off. My first truck was 2wd c-10 street truck and i loved it.
  4. Jan 30, 2011 at 11:30 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    only way i can think of doing that is taking an IRS and weld it in place of the entire rear suspension. up front i'm not too sure on how to accomplish that
  5. Jan 30, 2011 at 1:23 PM
    pinktaco808
    pinktaco808 Hot Steppa
  6. Jan 30, 2011 at 1:28 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    you could get shorter coils and take a leaf out of the leaf pack...
  7. Jan 30, 2011 at 1:32 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    I can't see why this wouldn't work. Sounds simple enough. Might have to get lower bumpstops as well.
  8. Jan 30, 2011 at 1:39 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yup, but shouldn't be a problem if your doing a moderate drop, like 2 inches...
    fairly cheap too!
  9. Jan 30, 2011 at 2:29 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Why go IRS when you could just go spring under axle?
    huh?
    Yeah thats what I was thinking about the front, like I said about the rear just got SUA alot easier and don't lose spring strength.
    Well to each their own on lowering, but wouldn't the CV's be ok if you lowered it to where the CV's sit almost horizontal because isn't that what Dif drops try to achieve?
  10. Jan 30, 2011 at 2:34 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yes, but if you lowered the truck you'd have an opposite angle than a lifted truck, so a drop bracket kit would make the angles worse in that case.
    so do a spring under and get some shorter coils, or cut yours down
  11. Jan 30, 2011 at 2:34 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    FYI diff drops work for 1st gen's just not really for 2nd gen's
  12. Jan 30, 2011 at 2:35 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    I don't mean throw a Diff drop on a lowered truck, I mean on lifted trucks because everyone tries to achieve some perfect angle.
  13. Jan 30, 2011 at 2:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yea, still, stock height the cv's are horizontal, lowering the truck will put them at a harsher angle than intended, same as lifting, but not a huge issue
  14. Jan 30, 2011 at 2:39 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yea just from my reading that's the general consensus. good news for me!
  15. Jan 30, 2011 at 2:41 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Yeah I see what you mean. So basically the cv angle would be "inverted?"
  16. Jan 30, 2011 at 2:44 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    you got it, opposite of a lift, but still you can drop it 2.5 inches with no problems
  17. Jan 30, 2011 at 2:45 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    :turtleride:
  18. Jan 30, 2011 at 2:46 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Yep. So from where I'm at(2.5"front/2"rear lift) I'd get a 5" front drop and however much swapping back to stock shackles and going SUA
  19. Jan 30, 2011 at 2:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yup that's right! I wish you had aftermarket coils to give me. shoot! :p
  20. Jan 30, 2011 at 3:36 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Yeah I bet. Lol. I'm gonna have to photochop this idea later because I'm actually kind of interested in this now. :spy:
