Just Used fluid film on my 2013 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tb3625, Nov 11, 2015.
  1. Nov 11, 2015 at 2:52 PM
    tb3625
    tb3625 [OP] Well-Known Member
    Tyler
    Ohio
    2013 Tacoma access sport
    I went out and bought a gallon of fluid film from my local john deere dealer today. I washed down the frame and waited an hour or two. Then used a paint sprayer hooked up to my 60 gallon compressor and went to town. I did the whole frame, transmission crossmember, leaf springs, inside of the rear bumper, sprayed for about 20 seconds on each boxed section of the frame, inside the trailer hitch, the spare tire and as best I could on the inside of the rear fenders and the rear diff. I'm hoping I used enough, I used about 1/8 of the gallon, in one of the pics you can see how I rubbed my finger in the oil to see how thick of a layer I put on. You can see where I touched I circled it in red. Everything was sprayed consistently. Any input on how good the layer of fluid film is would be appreciated. Jist wondering if i put enough on cause I live in northeast ohio, Thanks20151111_173937.jpg 20151111_164850.jpg 20151111_165143.jpg 20151111_165153.jpg 20151111_165031.jpg 20151111_165039.jpg 2015-11-11 17.46.29.jpg
    EDIT:
    Used the new "economy" cheapo undercoating gun I bought from summit. It didn't come with the bottle on the gun, the bottle was an additional $5. Anyway this undercoating gun put the fluid film on THICK. oh well, if anything it will give me a good price of mind. I used 3/4 of a gallon, let me know your thoughts on if I used too much with this new gun. Check out the new pictures below and let me know your opions either positive and negative.
    20151114_101009.jpg 20151114_092001.jpg 20151114_092029.jpg 20151114_092043.jpg 20151114_092017.jpg
    Coolerman, jmich2001 and DrFunker like this.
  2. Nov 11, 2015 at 5:38 PM
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    Looks good to me but this is my first year with FF too. Make sure you got inside the boxed portion of the frame in the front. From what I've read that is where it's likely to rust from the inside out.
    tb3625[OP] likes this.
  3. Nov 11, 2015 at 5:42 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    The more the better.... but that looks decent. I redo mine once a year.
  4. Nov 11, 2015 at 5:44 PM
    John4x4
    John4x4 Active Member
    Bucks County, Pennsylvania
    2015 DCSB 4x4 V6
    2.25 inch procomp leveling kit
    Also my first year with fluid flim, so far I like it used around quarter of a gallon. Water seems to bead up when it comes into contact with the FF, which I assume means it's doing its job. I've heared noting but good about the product.
  5. Nov 11, 2015 at 5:48 PM
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    What kind of spray gun is that? I was thinking of ordering the whole package from the internet with the upgraded spray gun, but its pretty expensive.. Also im not sure i can use the gun for paint or if its just for the fluid film.
    thanks
  6. Nov 11, 2015 at 5:59 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I use about a gallon a year.
    ...maybe I overdo it a smidge. The first year I painted it on like paint. I now have the sprayer so I probably use less, but I definitely used 3/4 of my can last year.
    EDIT: I saturate inside the box sections. This past summer FF was weeping out of my frame any day the temperature was above 85°F.
    DrFunker likes this.
  7. Nov 11, 2015 at 6:28 PM
    tb3625
    Tyler
    Ohio
    This is the $20 harbor freight special that has been laying in my garage for 8 years. And with the ff specific guns I don't think you can paint with them, unless maybe you get the adjustable one.
  8. Nov 11, 2015 at 7:41 PM
    tb3625
    Tyler
    Ohio
    How did everyone end up doing the boxed section? I just held the sprayer in there as far as I could for like 40 seconds on each side.
  9. Nov 11, 2015 at 7:53 PM
    ImpulsedComa
    NJ
    Thanks, does it have the item number on it? The Harbor Freight website has two guns that look like yours. One is an automotive gun that uses 20-55 psi or a heavy duty one that uses 60-115 psi?
  10. Nov 11, 2015 at 8:01 PM
    tb3625
    Tyler
    Ohio
    It worked okay for something I had laying around, sometimes it wouldnt feed real well so I had to adjust the top thumbs crew on the handle. I've been looking into it and it sounds like from what I've read these work better
    http://m.summitracing.com/parts/smm-71101
    ImpulsedComa[QUOTED] likes this.
  11. Nov 11, 2015 at 8:02 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  12. Nov 11, 2015 at 8:05 PM
    tb3625
    Tyler
    Ohio
    I almost ordered the exact same thing, except they had it with a spray gun and 1 gallon rather then 2. I read up on that style of spray gun and my friend uses the one I posted from summit racing which looks just like that one and he says it works real well.
  13. Nov 11, 2015 at 8:06 PM
    ImpulsedComa
    NJ
    thanks!
    tb3625[QUOTED][OP] likes this.
  14. Nov 11, 2015 at 8:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  15. Nov 11, 2015 at 8:10 PM
    tb3625
    Tyler
    Ohio
    No problem, I'll probably buy that sprayer that I posted the link from summit racing since it's only $16 and I live 30 min from there. I'd like to try it since my harbor freight sprayer didn't feed the oil well. Also I tried the harbor freight spray at different pressures, I found it worked best at 60 psi, and it didn't feed at all below 45psi.
  16. Nov 11, 2015 at 8:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So do I need to be careful to not get it on anything special? I am getting a Full lift kit put in this weekend and would like to order that 1 gallon can kit with gun. And do it next week, it is okay to get it on shocks, springs, leafs etc etc etc
  17. Nov 11, 2015 at 8:11 PM
    tb3625
    Tyler
    Ohio
  18. Nov 11, 2015 at 8:13 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Any worries of getting it on anything specific? And what do I clean the gun with?
  19. Nov 11, 2015 at 8:17 PM
    tb3625
    Tyler
    Ohio
    I sprayed it on my leaf springs. And it say it should harm paints or plastics, also I've watch videos by fluid film showing them using it as a tire shiner so I'd assume it's safe for rubber. In the video they use it as a tire shine a the 2:10 mark
    http://www.fluid-film.com/applications/automotive/
    http://m.youtube.com/watch?v=ICPiDOyA4T4
    Manwithoutaplan likes this.
  20. Nov 11, 2015 at 8:21 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
