Just wasted 5 hours to fing out 2 inch wheel spacers wont work with 285's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sheepdog, Sep 17, 2010.
  1. Sep 17, 2010 at 3:28 PM
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    I got some 2" wheel spacers for my truck via cragislist and I painted the hubs and the inside of the spacers black to match the wheels. I installed the rear ones and then took it for a test drive to make sure everything was good to go, and it was. Then I installed the front ones, went to take it for a drive and when I turn hard to either side, it rubbs like a son of a bitch. Now I'm out 100 bucks with 4 useless peices of shit.
  2. Sep 17, 2010 at 3:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    trim it
  3. Sep 17, 2010 at 3:37 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
  4. Sep 17, 2010 at 3:38 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Sell them to me :D
  5. Sep 17, 2010 at 3:45 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Trim it. Even with three inches most have to trim
  6. Sep 17, 2010 at 3:52 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Where is it rubbing? Thinking about doing the same thing myself and would like to know what I'm getting myself into.
    Also, what wheels are you using? Know the backspacing by chance?
  7. Sep 17, 2010 at 3:52 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    2 inch wheel spacers are big. thats 4 inches of total width to your truck
  8. Sep 17, 2010 at 5:07 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Get rid of the spaces/adapters, and get wheels with the correct off set.
  9. Sep 17, 2010 at 6:09 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I just put spidertrax 1.25" spacers and wheels with 5" backspacing on and all I had to trim was the bottom of the plastic inner fender by the cab and I beat the pinch weld down a little and it will go lock to lock without rubbing but I need to hammer on the pinch weld a little more because if I'm turning and hit a bump it rubs some.
    edit: I also have a 3" lift and 285/75s.
  10. Sep 17, 2010 at 7:02 PM
    Sheepdog
    Gary
    San Diego, CA
    The tires are rubbing on the outer side, so when I turn hard driver, the driver front tire rubbs on the back part of the wheel well and vise versa. I looked and theres no way I can trim it because when I installed my bushwackers I had to cut the firewall and bend it back. Theres no more room to cut or bend anything.
    I'm not sure what the offset of my wheels are but the front tires, with the spacers stuck out maybe an inch past my bushwackers, and the rear was a little less, maybe 3/4 inch?
    And to jdtemple, I'm not getting rid of my wheels becasue I like them.
  11. Sep 20, 2010 at 5:34 AM
    Southern01Taco
    Sean
    Holden, La
    How much room do you have between your control arm and tire? If it is a good bit, I would try a smaller spacer.
  12. Sep 20, 2010 at 5:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    same thing happend to me dude. I trimmed the shit out of everything and they still rubbed, I had to just get ride of them.
  13. Sep 20, 2010 at 6:23 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    you can trim the spacers as they actually make rubbing worse the thicker they are. kinda need a milling machine though. or you could take them to a machine shop and get them to cut a half inch or so off them and then see if they will work..
  14. Sep 20, 2010 at 8:50 AM
    Sheepdog
    Gary
    San Diego, CA
    The tires rubbed tire UCA untill they got down to about 60%. Now theres only like a half inch gap between the two when it's just sitting.
  15. Sep 20, 2010 at 10:38 AM
    Southern01Taco
    Sean
    Holden, La
    Is that with the spacers or without?
  16. Sep 20, 2010 at 12:03 PM
    7tac0ma7
    7tac0ma7 Member
    Spencer
    humboldt
    99 Tacoma 6" lift/fiberglass fenders
    6" fabtech lift, king coilovers, 5125 rear bilsteins, 2.5" skyjacker softride leaf springs, 33x12.50 toyo mt's, 15x10 ion alloy powdercoat wheels, downey fiberglass front end, k&n air filter, flowmaster dual exhaust, factory e-locker
    ILL BUY THEM!!!
  17. Sep 20, 2010 at 5:45 PM
    Sheepdog
    Gary
    San Diego, CA
    Without. Theres about 2 inches WITH the spacers. lol
  18. Sep 21, 2010 at 5:33 AM
    Southern01Taco
    Sean
    Holden, La
    Oh ok. Then yea, I would definitely try to either get those machined down some or sell them and buy some smaller ones.
  19. Sep 21, 2010 at 5:44 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    lol:cool:
  20. Sep 21, 2010 at 9:32 AM
    Sheepdog
    Gary
    San Diego, CA
    That's what I'm gonna try to do. I'm pretty sure 1.5" spacers will work.
