Just wondering if I have tranny problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by smoothguy, Apr 16, 2011.
  1. Apr 16, 2011 at 5:00 PM
    smoothguy
    smoothguy [OP] Member
    jon
    east ky
    2000 tacoma 4x4 2.4 5 speed
    I just purchesed my first toyota tacoma 2000 4x4 2.4 liter 5 speed. The only problem that I have noticed is that when I get into 4th or 5th gear going up hill it starts to bounce. I don't know if it might be a tranny issue or maybe drive line or diffrential problem. also the truck has 208000 on it
    Thanks
    Jon
    Th
  2. Apr 17, 2011 at 5:26 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    You are in the wrong gear.
  3. Apr 17, 2011 at 8:56 AM
    smoothguy
    jon
    east ky
    I can down shift and still bounces like it's having trouble pulling
  4. Apr 17, 2011 at 9:01 AM
    Big Tuna
    Big Tuna Member
    Andrew
    Orange County, CA
    I had the same problem a while back, flushed the tranny fluid and haven't had it happen again since. Worth a try of you haven't done in a while
  5. Apr 17, 2011 at 9:22 AM
    smoothguy
    jon
    east ky
    cool i give that a try see if does it any good
  6. Apr 17, 2011 at 4:06 PM
    Murrfk
    Murrfk Well-Known Member
    Manitoba, Canada
    1996 Tacoma 2.7l
    Might also be the clutch disk or that the flywheel needs re-surfacing.
  7. Apr 17, 2011 at 4:08 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    our ford ranger at work was doing this if you lug it our get into the gas to fast, new plugs and wires, and it was fine!
  8. Apr 18, 2011 at 4:24 AM
    smoothguy
    jon
    east ky
    Don't know about the clutch it feels good and tight smooth when changing gears. It might be plugs and wires I'll take a look at that also
    Thanks for the help
  9. Apr 24, 2011 at 5:32 PM
    smoothguy
    jon
    east ky
    I have tried a a can of lucas and some high test gas still got a little bounce in it
  10. Apr 28, 2011 at 4:36 PM
    smoothguy
    jon
    east ky
    found the problem it was the e brake sticking causin it to bounce when I get up to higher speeds. sure am glad it wasn't nothing major.:D:D:D
