Justin's IFS Torture Test; Build and BS thread
Discussion in '1st Gen. Builds (1995-2004)' started by Justinogo, Jan 19, 2018.
  1. May 12, 2018 at 8:54 PM
    #401
    Justinogo
    Justinogo [OP] Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    16.5 mpg this tank, all work commute and trips around town, no highway :D loving the high gears. I can hold 75mph at 2100rpm and still have some passing power
    11TRDTX likes this.
  2. May 21, 2018 at 6:31 PM
    #402
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    At this point it'll almost be easier and cheaper to SAS my truck with a donor fj60 instead of fixing my IFS problems... saw one on craigslist for $800 with a blown motor. Very tempting.
    Need daily.
    slander and beertimecontinuum like this.
  3. May 21, 2018 at 7:43 PM
    #403
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Doooo iiiittt
    Justinogo[QUOTED][OP] likes this.
  4. May 21, 2018 at 8:13 PM
    #404
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Daily first...
  5. May 21, 2018 at 8:16 PM
    #405
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This is the reason I have stack of OEM manual hub CVs that I've harvested over the years. Parts store ones are just junk.
  6. May 21, 2018 at 8:56 PM
    #406
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Wise. What needs fixing?
  7. May 21, 2018 at 9:23 PM
    #407
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Axle seals, steering rack bushings, front shocks and coils, just replaced a bad tie rod, small leak in the steering rack, just replaced one UBJ nur the other is pretty warn. Ifs skid mount broke off. Front diff bushings are worn... bunch of little things. Want a daily and a donor Land cruiser or mini truck
  8. May 21, 2018 at 10:05 PM
    #408
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    Most of that stuff is pretty easy to fix and are problems that probably everybody has since these trucks are getting pretty old. I know my diff bushings are probably garbage and my lower control arm bushings are trashed. But you could probably knock most that out in a day or two and have a solid front end for a bit. Until those 35s wear it all out again.
  9. May 22, 2018 at 6:29 AM
    #409
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Well I know I could do it fairly easily with less than $100 and a full day, minus replacing the shocks and springs of course, i just feel like it's almost not worth it to tear down the whole front suspension and the front diff and put all that work in it, then swap it later anyway. Wish i had the resources to just do the SAS now, but I'll have to keep bandaiding the IFS until I do
  10. May 22, 2018 at 7:21 AM
    #410
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, here's irony for ya. Went out last Saturday and managed to pop the birf on my last factory CV (at least it was the birf this time and not the stub axle), but the NAPA CV on the other side stayed intact all day. It was probably just bad luck or the wear and tear finally got to it, but I was pretty impressed I didn't pop the NAPA CV as well. They are definitely stronger than the Autozone junk, but I'll snap one eventually. since I'm replacing the factory CV with another NAPA one. Lifetime warranty and all that. I'll accept a trade off between free replacements and breaking them more often up to a point. The Autozone one's broke far too frequently.
  11. May 24, 2018 at 8:15 PM
    #411
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    @slander you think that's still available?? It would be awesome, just need somewhere to store it
  12. May 25, 2018 at 4:26 AM
    #412
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It was a rear axle. Check ih8mud classifieds though, those fj60 axles go for cheap!
  13. May 25, 2018 at 8:14 AM
    #413
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Gonna need one of those at some point too haha, not yet though. Thanks for looking out, I'll keep an eye out for a front. Still looking for daily but waiting on money
  14. Jun 4, 2018 at 2:05 PM
    #414
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    -Xgd_LUZx2kyuZbqRdp4Yu2lWFINOmvB-kI5T7D3_eb3ecc83a1e9f46b951870972bda5f0c29a336c1.jpg
    Going to have to change the name of this Thread soon :cool:
    jubei, dirty deeds, 11TRDTX and 2 others like this.
  15. Jun 4, 2018 at 3:01 PM
    #415
    DoubleC
    DoubleC Well-Known Member
    Christian
    Oxford, MS
    1999 Tacoma 3.4 TRD (Natural White - the best white)
    Yep. Excited to see the outcome
    11TRDTX likes this.
  16. Jun 4, 2018 at 3:04 PM
    #416
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    He's alive! How has your truck held up since march?
  17. Jun 4, 2018 at 3:05 PM
    #417
    DoubleC
    Christian
    Oxford, MS
    Hahaha. It’s all good. Got a shock mount welded and the IAC cleaned. Runs like a charm
    11TRDTX[QUOTED] likes this.
  18. Jun 4, 2018 at 3:45 PM
    #418
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Got IFS hubs and steering box shipping here tomorrow too. Need hi steer arms and leaf springs next
  19. Jun 5, 2018 at 9:27 AM
    #419
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    @slander You flipped your third member to be oriented correctly after flipping your axle right? And have to cut off the back of the pumpking, flip it, and weld it back on so the ring gear clears?
    Aside from that I just have to strip the stock brackets, rotate the knuckle balls to set caster, then build leaf mounts and that's about it, correct?
    Sorry, big fat newb here. Everyone with experience can expect a lot of questions
  20. Jun 5, 2018 at 10:25 AM
    #420
    slander
    Hickory, NC
    Look up ZUKs build on yota tech. If you Google "ZUK Tacoma SAS" and look for his build thread on yota tech. I used that as my template as he flipped an fj62 front axle and does an excellent writeup. Long story short you do not do anything to the third, just cut off the diff cover and grind cutouts into the housing. As for the knuckle balls, they get flipped and swapped side to side.
    My recommendation: don't flip the axle, swap in a gear drive pax drop dual case setup with a gear drive transfer case. It's quicker, yea it's more $$$, but duals are a better mod than an SAS anyway and should be done at the same time anyway. I would not flip an axle again. The only reason I did it was because I already had a ton of $$$ dropped into my dual setup and could not sell it for what I needed to build new cases.
