JW speaker on 96 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by therealmasarap, Jul 11, 2022.
  1. Jul 11, 2022 at 2:03 AM
    therealmasarap
    therealmasarap [OP] New Member
    1996 Tacoma 4x4 V6
    Bone stock
    Hello, just purchase a set of JW Speaker 8900 evolution 2. Installed it on my 1996 Tacoma plug it in and no lights low and high. Do I need to modify/rewire it?
    1997tacomav6 likes this.
  2. Jul 11, 2022 at 3:53 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Apparently they're LED/projector headlights. I, too, was thrown off by the "Speaker" and lights references. @therealmasarap, did you also order the harnesses?
    Taco critter likes this.
  3. Jul 11, 2022 at 5:17 AM
    1997tacomav6
    Denver
    I’m going to say you probably will need a separate harness with direct power off the battery,
    Not hard to do
  4. Jul 11, 2022 at 6:25 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    You likely blew the 10A headlight fuse too. Looking at their tech sheet,
    @12v the low beams draw 4.3A and high beams draw 5.3A. There will be voltage drop due to the stock wire size so I doubt you have full 12v at the headlight plugs so current draw will be a little higher AND there are 2 headlights so double those figures and you easily exceed 10A.
  5. Jul 11, 2022 at 6:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
