K&N 63 series help
Discussion in 'Performance and Tuning' started by spitfire501, May 24, 2012.
  1. May 24, 2012 at 11:47 PM
    spitfire501
    spitfire501 [OP] Well-Known Member
    Austin
    Napa, CA
    I have an '09 taco prerunner and i wanted to put the K&N 63 series air intake on my truck. my truck is only 2 wheel drive. i had a couple of questions: 1)is this worth my time effort and money? and 2)is it a relatively simple installation?
  2. May 25, 2012 at 11:07 AM
    Burritos Taco
    Burritos Taco Active Member
    North Texas
    05 DCSB 4x4 6sp
    Bilstein 5100s set at 1, 5160s rear,URD MAF calibrator, KN 63 series,DT Longtubes,Magnaflow cats, Walker Quiet Flow muffler, 2x Vibrant ultra quite resonators, TRD quickshifter
    Yes and yes.
    Shouldn't take you more than thirty minutes to install.
    I have one and with the stock exhaust you won't hear anything until you mash on it, and then it sounds wonderful.
    I uploaded a video of when it was just the KN and nothing else installed.
    www.youtube.com/watch?v=CAhSrZgU-vw
  3. May 25, 2012 at 11:21 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No.
    It's also potentially damaging to the engine. The K&N does not filter worth a shit. Stick with stock paper. The stock intake and filter flow more than enough air to feed a 4.0... your 2.7 is not stressing it.
    Sure. I'd call it a 2-beer job.
  4. May 25, 2012 at 11:23 AM
    cgs2k2
    cgs2k2 Ohio Member
    Nadeem
    2006 AC 4x4 OR
    Its very easy to install even if you're a nooby to car stuff.
    I had one, but took it off. I don't think it's worth it. Sounds awesome! But otherwise you gain nothing but heatsoak.
  5. May 25, 2012 at 11:28 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I had one. took it off and sold it. your stock intake is a "cold air intake"
    the K&N is a hot air intake. do you think that little metal shield really keeps the hot engine air out of the filter?
    if you want a little more power, save up and get headers and a URD MAF CAL
  6. May 25, 2012 at 1:07 PM
    spitfire501
    Austin
    Napa, CA
    i do have the 4.0 v6 in it so thats why i was wondering about this upgrade. are there any others out there that would be more beneficial? im looking to get the sound as well as some extra power out of this
  7. May 25, 2012 at 3:35 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Scroll to the bottom of this thread and you will see more threads of the same topic. Read through those. This subject is discussed almost daily on TW
  8. May 25, 2012 at 3:44 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    i have one on my 2005 4.0 v6 and i love it, the only down side is oiling it.
  9. May 25, 2012 at 4:32 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    And poor filtering. And hot air intake. And the price
  10. May 25, 2012 at 8:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +10,000
    Like oil consumption far above normal for Toyota at 100,000 miles.
    Crosshatch from the factory honing still visible at 50k (good), with severe cylinder scoring (bad).
    Commentary from Blackstone on used oil analysis stating that the elevated silicon levels indicate a possible sealing issue in the intake system or a torn air filter.
    Want noise? Get an exhaust. It might even bump your performance a bit.
