K&N air filter problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by obie3, Mar 3, 2013.
  1. Mar 3, 2013 at 1:55 PM
    obie3
    obie3 [OP] Active Member
    Bob
    Northeast
    02 Prerunner TRD
    K&N air filter
    I have a 2002 Tacoma pre-runner 4x4 V6. Bought it used in 08, it came with a cone shaped K&N air filter. Every few months my check engine light comes on and code reads " to lean, bank 1" or something similar to that. I wash the filter, but don't oil it, and I clear the code with my code reader, " cheaper Black & Decker reader. It clears and then comes back a few months later. Any take on these filters, and should I revert back to the stock system that was on it when previous owner purchased it? How much would that cost? Thanks.
  2. Mar 3, 2013 at 2:23 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  3. Mar 3, 2013 at 3:37 PM
    obie3
    Bob
    Northeast
    02 Prerunner TRD
    K&N air filter
    Thanks, but I think I'm leaning more towards the air filter. I've read pros and cons of the K&N's. Hopefully that's the only problem.
  4. Mar 3, 2013 at 5:13 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    for the K/N filter to work right it needs to be oiled. You also might need to clean the MAF sensor, since that could have some dirt buildup on it now. I had one for 8 years, and to be honest the oil type filter is not worth the trouble. Their are good high flow filter on the market now that don't require oil, now not sure if they make them in the cone shape, I am sure they do, but you are not doing yourself any favors or your engine any favors by not oiling the filter.
  5. Mar 3, 2013 at 5:24 PM
    obie3
    Bob
    Northeast
    02 Prerunner TRD
    K&N air filter
    Thanks again, I think I'll look for a replacement for the cone filter, maybe they make some kind of sleeve that would fit over the cone. I know I'm not doing myself any favors by not oiling the filter, I should have said I have not oiled it lately, ( since last washing). Thanks again.
  6. Mar 3, 2013 at 5:52 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    like my fipk/#3004 K&N element.
    lifetime warranty it has.
    I had a 12 year old element that had
    a little dry rot occurring.
    receipt not needed...
    emailed a picture of mine...
    had a new one at muh door in a few days.
    Your issue is not with the K&N... but something else
    (unless installed improperly)
    my fipk has been working well for many years use.
    has never caused a code or cel
  7. Mar 3, 2013 at 6:45 PM
    obie3
    Bob
    Northeast
    02 Prerunner TRD
    K&N air filter
    The code is always the same, and after I clean the filter and clear the code it won't show up again until the filter needs cleaning again, so that would lead me to believe it is the filter getting dirty and causing the "to lean- bank 1" code to come up. It's the same code every time, and will not come up for several months after cleaning, so if it was some other issue it would, I believe, show up again sooner than it has been. Thanks for the input, any info on the subject is a good thing.
  8. Mar 3, 2013 at 7:19 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    lean bank one means its two cylinders (as its three coils, each powering two cylinders), where as the filter provides air to the entire engine, banks 1, 2, and 3. all your doing with an extremely clean filter, even if it is choking is providing more air. making up some of the problem.
    id provide us an actual code....
    First, Id change the spark plug wires (extreme heat and cold can damage them faster then the spark plugs themselves.
    Then check the spark plugs themselves, yes the two back ones can be a bear, but when was the last time youve done it?
    Then a coil for bank one. autozone rebuilt ones have done just fine for me.
    all this is after cleaning the maf, but the maf is a seperate code from the lean bank one.
    The filter does not have a sensor, like i stated, cleaning the filter is providing more air simply overcorrecting the issue at hand.
  9. Mar 3, 2013 at 7:54 PM
    obie3
    Bob
    Northeast
    02 Prerunner TRD
    K&N air filter
    Well that just tells me that I don't know shit about those codes. Very interesting, I will change out the plug wires and the plugs because honestly I have'nt changed them and don't know if the previous owner did either. Thanks for the info. This is what makes these forums indispensible. Thanks man.
  10. Mar 3, 2013 at 8:03 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Nada problem. post up the codes, get a ultragauge during the next group buy, even goes as far as to show how much air the maf sensor is getting.
  11. Mar 3, 2013 at 8:10 PM
    42boxer
    42boxer Well-Known Member
    Brannon
    Mcguire AFB, New Jersey
    2000 Toyota Tacoma TRD
    Plenty to come
  12. Mar 3, 2013 at 8:49 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    have you tried cleaning the maf? replacing can be an option. i did mine. vatozone.
  13. Mar 3, 2013 at 10:25 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I've always used Isopropyl alcohol and a Q tip.
    been doing that for 13 years... no issue
    ^ always in the cupboard next to the medical supplies
    or maybe I'm just too cheap to spend
    money on a spray product that's not necessary.
    just need to be cautious not the crack or break
    the glass sensor element.
    if yer ham or monkey fisted... get the spray :p
  14. Mar 4, 2013 at 11:31 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Amen. The TRD filter is no better. I got rid of mine, cleaned my MAF after several CEL problems (P0171), switched to paper and never looked back.
    I would use dedicated MAF sensor cleaner though.
  15. Mar 4, 2013 at 4:43 PM
    42boxer
    Brannon
    Plenty to come
    So ironically after telling yoy how to fix it my truck went to shit today. Rough idle and just bogs when i accelerate. i had if floored just to get to 30. Its not even drivable. Im gonna get a new MAF and see what happens.
    Anyone know of a place online i can order one? Imma call the salavge yard tommorow and if n luck i need to order one.
  16. Mar 4, 2013 at 4:58 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Could be a clogged catalytic converter as well.
  17. Mar 4, 2013 at 5:50 PM
    42boxer
    Brannon
    Plenty to come
    I just spent 90 bucks on a maf and its not the problem... now idk what to do...
    Can the cat cause a sudden problem like this?
  18. Mar 4, 2013 at 5:56 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    maf sensors are one of the few things id say aftermarket are ok. go vatozone, cant beat the warranty and price, as for napa better quality, less warranty.
    before you start throwing codes at it, use a code reader.
    rockauto, autozone, numerous toyota oem dealers, ebay, Amazon, all places to buy car parts. oreily and napa im sure also ship.
    clogged cats dont just happen suddently, they build up.
  19. Mar 4, 2013 at 6:06 PM
    42boxer
    Brannon
    Plenty to come
    I went to o reillys and bought a cardone maf for 80 bucks and its still broken...
  20. Mar 4, 2013 at 6:39 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    the new maf sensor is broken? return it.
    the problem persists? guess that wasnt the problem/the whole problem.
