K & N air filter vs Denso/tacoma replacement and Octane rating 89 or 91
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skazone, Mar 27, 2020.
  1. Mar 27, 2020 at 12:02 PM
    Skazone
    Skazone [OP] Member
    Tony
    BC Canada
    Stock 2014 trd sport magnetic grey
    Morning guys,
    My apologies if this has been posted before... Im looking at replacing my air filter for my new* tacoma. Its a 2014 Trd sport and I was looking at getting a K & N air filter. Its re useable and I have extra cleaner/oil from a previous filter on my Mazda. https://www.knfilters.ca/33-2281-replacement-air-filter. Is this filter worth it? or should I stick with a toyota one? Also what fuel do you guys run? Manual says 89 is fine but the manual says to (research 91).
    Thanks in advance and have a good one!
  2. Mar 27, 2020 at 12:16 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    AFE ProDry with charcoal filter removed on my 15. 87 octane I get 21-23 mpgs. I stay away from oil gauze air filters.
    Skyway and Biscuits like this.
  3. Mar 27, 2020 at 1:49 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    There is no real reason to get a K&N oiled air filter IMO. I have one and if you live in a particularly dusty environment I think it actually works worse. Would stick with stock IMO. I've mostly run 87 octane since I've owned the truck. I get pinging if i accelerate hard with 87 though. This tends to go away when running higher octane fuel. Your results may vary by region.
  4. Mar 27, 2020 at 3:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OEM is going to filter better than everything else and cause no restriction on an NA'd motor.
    Stock intake is a cold air intake, dont fall victim of "aftermarket CAI gives more power"
    87 is perfectly fine, the truck sorts itself out as far as timing goes to reducing pinging.
    Also no need to remove charcoal filter as it does not restrict / impede air flow at all.
  5. Mar 27, 2020 at 3:30 PM
    Sxottie
    Sxottie Wrenching is therapy, right??
    Scott
    Mystic, CT
    2021 TRD Sport Double Cab
    Tonneau hard cover, mud guards, yellow fog light tint, redline hood lift kit, remote tailgate lock, bed lights, window tint, invisible bra, TRD wheel cap decals, tailgate letters, blackout badge kit, LED cab lighting kit, bed hooks, red caliper paint.
    I went with a K&N filter and also removed the charcoal filter. It makes a difference. Additionally running highter octane will help overall.
  6. Mar 27, 2020 at 3:40 PM
    Th6nh
    Th6nh Let's taco bout it
    SoCal
    2020 4x4 Tacoma TRD OR
    Need that aftermarket so it sounds like it has more balls
  7. Mar 27, 2020 at 3:44 PM
    Sxottie
    Scott
    Mystic, CT
    No, that would be accomplished with a CAT back exhaust.
  8. Mar 27, 2020 at 3:51 PM
    Th6nh
    SoCal
    With just a cat back it sounds equivalent to a honda civic
    ehanvey likes this.
  9. Mar 27, 2020 at 3:53 PM
    nd4spdbh
    SoCal
    neither will provide any performance or mpg benefits.
  10. Mar 27, 2020 at 3:54 PM
    John90XJ
    John90XJ Well-Known Member
    2006 Tacoma Access TRD OR
    As for your octane rating, it really depends on what elevation you live and spend most of your time driving at. I'm in Reno at >5000 feet and anything other than 87 octane is a simple waste of money. If I were down close to sea level, a higher octane option would like give some small performance bump. Depending on where you are in BC, you may or may not need to even think about it. Many higher elevation states like Utah and Colorado sell their base grade gas at 85 octane.
  11. Mar 27, 2020 at 4:08 PM
    Sxottie
    Scott
    Mystic, CT
    HAHAHAHAHAHA
  12. Mar 27, 2020 at 4:58 PM
    Skazone
    Skazone [OP] Member
    Tony
    BC Canada
    Thanks for all your responses.
    I went to Toyota and got a stock air filter. ($20 USD or 29 CDN)
    As for gas im at about 1/2 a tank, once i get to 1/4 Ill prob go with a top tier gas station like Shell, Chevron, Esso or Co op. I live in a valley elevation is 344m roughly (1128.61 feet).
