K&N Air Intake and Exhaust Tuning
Discussion in 'Performance and Tuning' started by BlackSport, Jun 5, 2016.
  1. Jun 5, 2016 at 10:48 AM
    BlackSport
    BlackSport [OP] Member
    So I am looking at installing a K&N air intake and a cat back exhaust on my 2013 Tacoma TRD Sport, and I was wondering if anyone had done similar mods and what type of tuning it requires after installation. I do apologize for being a newbie, I know there is a ton of info to research, but I figured I would post this to get a straight answer from someone who knows. Much appreciated.
  2. Jun 5, 2016 at 4:50 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Sadly neither will give you much in terms of power, but on the plus side your truck will sound way cooler. No tuning needed on our trucks for these mods. And just as a suggestion i would look into the URD catback exhaust and the AFE pro dry rather than the K&N.
  3. Jun 6, 2016 at 1:53 PM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    I was thinking of doing the same to my truck with the k&N, what make the pro dry a better choice. besides being more than half the price. Sorry I'm a newbie as well.
  4. Jun 6, 2016 at 1:54 PM
    Theloden
    Theloden Well-Known Member
    Joe
    Lakes of the North, Michigan
    '23 TRD Off Road
    It's a dry filter versus an oiled one. Oiled ones can cause issues with oil build up on the MAF and also need to be serviced occasionally. A dry filter can just be removed and blown out with an air compressor then reinstalled.
  5. Jun 6, 2016 at 1:57 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Well, given your truck actually has a cold air intake (CAI) then putting a K&N intake on makes is a hot air intake and thus reducing performance overall. Cost verse result doesn't add up for buying a CAI. Just buy an AFE pro dry filter and you'll be better off!
  6. Jun 6, 2016 at 1:58 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Great, thank you very helpful.
  7. Jun 6, 2016 at 3:51 PM
    BlackSport
    So I checked out both the URD exhaust and AFE intake, those are right up my alley. On the exhaust, are you recommending the URD stainless Mark 3 system, or the racing one? One says "not street legal", so Im guessing the Mark 3 system.
  8. Jun 6, 2016 at 3:56 PM
    BlackSport
    After putting on an intake and exhaust would I need to upgrade the fuel pump? Anyone have any trouble running too lean?
  9. Jun 6, 2016 at 4:52 PM
    WOODEX M.E.
    Corey
    Maine
    I meant the Mark 3, the other system is called their spec u system. It eliminate the y pipe from what i remember which is why its not classified as street legal since the y pipe has the two rear cats. The spec u is a better performer and sounder than most anything else on the market but you pay a steep price for it. The mark 3 is just a little more agressive than the trd. Its fairly quiet so you wont be annoyed.
  10. Jun 6, 2016 at 4:53 PM
    WOODEX M.E.
    Corey
    Maine
    Your fuel pump will be fine untill you go forced induction. At that point you can start worrying about it, but otherwise you are totally fine.
  11. Jun 6, 2016 at 8:45 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Just curious what AFE intake were you looking at?
  12. Jun 6, 2016 at 8:53 PM
    BlackSport
  13. Jun 6, 2016 at 8:56 PM
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Nice that is the same one I was looking at. You may want to check it out on Amazon as well.
  14. Oct 9, 2016 at 5:04 AM
    lemontaco
    lemontaco Member
    Grant
    '15 TRD 4x4
    Camper top
    Christ! 426 for some plastic tubes/box and a filter. What a crock of sh**. From the reading I've done on here, a new air intake system is worthless. Unless it's supercharged. Just keep you a clean filter in there. I am considering the TRD exhaust... If I can find one for a reasonable price.
  15. Oct 9, 2016 at 9:13 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    And what gains will the trd exhaust give that a simple muffler wont?
  16. Oct 9, 2016 at 9:15 PM
    inwood customs
    Dave
    As for the afe stage 2 si.....it resonates so loud inside the cabin, its rediculous while n/a and passing, merging, or at just about any high load situation.
  17. Oct 11, 2016 at 10:30 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I think you're asking about a tuner/ piggy back controller.
    Adding an intake and exhaust will lean out the truck, but it will adjust good enough for normal driving.
    Some intakes could reduce power by throwing off the maf sensor readings and would require a tuner for positive results.
    Yes you will see gains from a tuner but there is no good bolt on and forget system.
    The maf cal and unichip are the 2 entry level tuners but you will still need to understand tuning to make it worth the money.
    Or you will have to pay a tuner. If you have a tuner close by that is familiar with Toyotas I should be very easy to get a good tune.
    So use an intake with lots of positive results and you should be ok.
  18. Nov 28, 2016 at 12:34 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Anyone with a 2nd Gen who is swapping (or has recently swapped) out your OEM air box/intake for one of the CAI, let me know if you'd be willing to sell it.
    I'm ditching my KnR because it's just been a headache. Have to get the special cleaning system, make sure it's properly oiled, etc. Some other stuff too including it falling off from vibration on a dirt road yesterday. I'm just over it.
    I'll pay a reasonable price and shipping to go back to stock.
  19. Nov 28, 2016 at 1:45 PM
    WOODEX M.E.
    Corey
    Maine
    I still have all my stuff. Its from a 13', so im not 100% sure it would work. As far as I know, it just had and extra bracket for air injection system. Someone else could chime in if they know. If you are interested what do you think a reasonable price is? I'm not here to gauge anyone so I think $65 + shipping is reasonable. It has the TRD air filter in it, which came with the supercharger system.
  20. Nov 28, 2016 at 1:53 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Where are you located?
