K&n air intake system?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elc1973, Apr 20, 2013.
  1. Apr 20, 2013 at 8:21 PM
    Elc1973
    Elc1973 [OP] Member
    Thinking of getting this anyone have any experience with it? Does it help boost fuel mileage? Power? Good bad or ugly I'd like your opinions.
  2. Apr 20, 2013 at 9:03 PM
    Q Source
    Q Source Well-Known Member
    California
    04 PreRunner
    Supercharged, TRD Headers, URD 7th/SHORTIE 800cc injector, Snow Performance Water/Meth Kit, Deaver FJ59, Icon UCA, Fox Extended Travel Remote Resi, TG Front and Rear Bumpers, Deckplate Mod
  3. Apr 20, 2013 at 9:22 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Will not improve mpg.
  4. Apr 20, 2013 at 10:01 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Will gunk up your MAF sensor, and eventually cause problems.
  5. Apr 20, 2013 at 10:26 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    you must be "chicken little" :rolleyes:
    there are a lot of reasons not to buy one...
    but that comment is like swiss cheese.
    btw... have had muh fipk for over 13 years...
    none of what you say has ever occurred.
    feel free to tell me where I've failed :rolleyes:
  6. Apr 21, 2013 at 5:50 AM
    Tacomanater
    Tacomanater Well-Known Member
    Washington County, NY (VT Border)
    '02 SR5, 4WD, V6, 5Spd
    JBA headers & exhaust, new cats, K&N CAI, new shocks, 2.5" lift, Prodigy P2, Timbren, snobord552 light bar (v.2), KC off-roads and Hella fog lights, Teflon A/R ATX 16" Ledge, Nitto Terra Grappler, (265/75R16's), ultragauge, curt roof rack on thule set-up.
    I've had one on my truck for about two years. No issues, but I can't say that it has done anything for mpg. One the noise side, when you jump on it, more noise/sound.....worth it overall????????jury is still out on that one, but I am not unhappy...just not so sure I'd do it again...the lifetime filter does help, tho, one less thing to replace..
  7. Apr 21, 2013 at 6:55 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    I studied the K&N air filters in depth approximately 12 years ago, so I don't know if their technology has changed. But the bottom line is that i didn't install one because i was not convinced that it would stop dust and other particulates from entering the combustion chamber of the engine as well as a good standard filter...ie, less restriction in the K&K means more dust gets through.
    I use high quality air filters such as NAPA Gold.
    I'm not trying to start an argument here....maybe someone with real technical data on the K&N can chime in... hopefully not someone with a dog in the fight (ie a K&N salesman)
    For me the most important function of an air filter is to keep sh*t out:D
    I do like their oil filters
  8. Apr 21, 2013 at 9:12 AM
    tan4x4
    Rick
    Folsom, CA
    There does appear to be 2 sides to the K&N 'issue'.
    I admit that I've have not actually used an oiled filter on an EFI rig, but
    have done research on forums like this, and decided against it
    because of the MAF problems experienced by others and the
    additional hassle of oiling properly. Why some have success with
    it and other do not, I don't know.
    There are many previous threads on this, including this one:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/230845-k-n-filters.html
    BTW, I ran a oiled K&N on my carbureted 22R about 15 years ago, but took it out after about a year, and went back to stock. Same experience with an aftermarket ignition, which actually failed completely after 18 months. Neither product lived up to the hype.
  9. Apr 21, 2013 at 12:12 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    maybe some folk can read, follow directions...
    while others cannot !? :notsure:
    But seriously...
    many folk are simply misinformed...
    It's the K&N "drop in" filter element for the oem air box
    that's more subject to the the over oiling issues.
    Because flow design is straight thru, plus a shorter distance to the MAF.
    No matter tho'
    just because oil residue gets on the MAF does not mean it's ruined.
    Nor is it difficult to clean by any means or standards.
    There are MAF sprays on the APS's shelves, to clean that.
    I'm not paying that much for it tho'
    Instead... I use rubbing alcohol and a Qtip (never had issue)
    ^ I clean off my MAF on occasion whether it needs it or not
    basic maintenance keeps performance at its peak. ;)
  10. Apr 21, 2013 at 7:02 PM
    whathefk
    whathefk Member
    I'll sell you mine.
  11. Apr 22, 2013 at 12:19 PM
    EWhitman11
    EWhitman11 Member
    Eli
    Washington
    03 Tacoma 4x4
    Ive got a K&N in my 03' Taco. My opinion is its worth it. I have definitely not noticed and increase in MPG, if there is any, its barely anything. The mainly notice the slight HP increase, and the way it sounds when you step on it a little more. I'm glad I bought mine but don't spend your money if you just want increased MPG
  12. Apr 22, 2013 at 1:55 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i have had mine on for about 5 or 6 years now...
    my truck is approaching 300,000 miles with no issue as i clean out the MAF sensor at least once a year...
    no MPG gains... i could care less about HP gains as i don't drive fast and furious...
    i do notice that the throttle is more responsive with the kit on, so i keep it...
    before that, i had the deck plate mod... i didn't notice much difference except for all the little creatures that would crawl into the hole and not figure out how to get back out...
  13. Apr 22, 2013 at 2:39 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    FYI, the drop in K&N has roughly half the surface area of the OEM filter. Its about %50 thinner with 24 pleats vs OEM 22 pleats. The aFe drop in filter retains the OEM size and has similar flow characteristics as the K&N drop in. IMO, the drop in is a waist of money.
