K&N CAI?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyHandGrenade, Nov 8, 2014.
  1. Dec 30, 2014 at 8:39 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  2. Dec 30, 2014 at 10:26 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    If that's the case, then I'll definitely pass.
    By my calculations, it would take around 2 years for me to break even IF I got a 1 mpg gain. I do plan on keeping the truck well beyond 2 years, but I certainly don't want to do anything to lose more mpgs...
  3. Dec 30, 2014 at 10:48 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    You got a few things going on there:
    1) Increased tire diameter
    2) Increased tire weight
    3) Increased aerodynamic drag with the lift
    4) The increase in tire size also is throwing off your speedo a bit, so your miles traveled per tank is off a bit as well (actually, the jump from 265/65 to 265/70 basically makes the speedo dead-on, whereas it was slightly fast before)
  4. Dec 30, 2014 at 10:52 AM
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
  5. Dec 30, 2014 at 12:02 PM
    CowboyTaco
    North Georgia
    11 TRD Sport
    Thank you, Capt. Obvious.
    Sorry, I couldn't resist that one. You are correct in all of those statements. When these tires wear out, I figure I'll go with the Yokohama Geolander AT next. However, I have 15k on my current General Grabber AT2 and still have 13/32 tread. Unless they get softer....I'm going to have these on there for a while.
    Hence, why I'm looking to move the tires with less fuel consumption. Any/all suggestions are welcomed.
    http://www.tacomaworld.com/forum/4-cylinder/34594-mpg-mods.html#post547096
