K & N cold air intake worse gas mileage
Discussion in 'Performance and Tuning' started by glaziers27, Jan 16, 2013.
  1. Jan 23, 2013 at 2:55 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You have to think 'placement of MAF'. Which is behind a free-er flowing filter. Thus the MAF is reading increased CFM of air.
  2. Jan 23, 2013 at 3:10 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    This was my first thought. OP didn't say when they did the swap. Might have been around the same time their usual watering hole switched over to crap blend for the season.
    I'm still stock on my '11, but I did do the K&N swap on my '04 Wrangler and it gave me a 2-3 highway MPG boost even though K&N said not to expect one. Or course my Taco has even more electronic crap on it than the Jeep did. :(
  3. Jan 23, 2013 at 3:13 PM
    Aw9d
    Aw9d That one guy
    They come over oiled because they sit on the shelves for years before they get sold typically.
    Once you get a new one, take it out of the bag and wash it good. Then lightly, lightly, lightly oil it. Clean the MAF as well. 99% of peoples problems with K&N is due to them soaking the piss out of it in oil. I've ran K&N's in everything I've ever owned, never once had an issue.
  4. Jan 23, 2013 at 3:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No its not. I have monitored the GPS's (grams per second) readings from the MAF with OEM intake, and others, and there is no change. The only thing affecting the reading is the amount of throttle thats open. The air filter is virtually invisible to the engine.
  5. Jan 23, 2013 at 3:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, colder air holds more O2, thus causing the engine to run more fuel. MPG generally suffer in the winter because of, not only the crap gas, but also the colder, denser air.
  6. Jan 23, 2013 at 3:45 PM
    dually
    dually Low and slow
  7. Jan 23, 2013 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I understand what you are saying. What Im telling you is, The GPS were not affected by the kind of filter installed. This is a direct measure of how much air is flowing thru the MAF. If more air was in fact going into the engine, it would have shown an increase in the GPS.
  8. Oct 10, 2017 at 6:05 PM
    skitzobeve42
    skitzobeve42 Member
    scott
    NY/CT
    2017 TRD SPORT
    Hey guys, I just installed a K&N 63 Intake on my 2017 TRD sport. I was getting 23-24 highway mpg but no I am getting 20-21 highway mpg if I’m lucky. I take the same route everyday. I’m not sure why I am getting less MPGs. Does anyone have any suggestions ?
  9. Jul 16, 2019 at 2:39 PM
    Jasonsfirsttaco
    Jasonsfirsttaco Well-Known Member
    2007 4cyl taco access cab
    3in leveling kit with strut spacers and add a leaf, bull bar, 2 cube off-road ditch lights, 20in light bar, 4x 6in light bars, painted rear bumper, grill change, new head lights, black out badges, thule roof rack/ amazon roof basket, 17in rims, 245/70R17 AT tires, tri fold bed cover, rubberized undercoating, KYB Gas-A-Just shocks, running boards, new speakers, bluetooth audio, black box MOD.
    I installed a CAI on my 07 2.7l taco and the MPG went from 20 to 16.5-17
  10. Jul 17, 2019 at 6:28 AM
    Jasonsfirsttaco
    I just ordered a replacement air box and resonator, I'm not dealing with this BS gas mileage I'm just putting in a new stock system. For the 2 HP past 3k RPM and a little louder its NOT worth it at all. Couldn't find anything from any junk yards so I had to order the parts from ebay. Luckily I didn't get a K&N so I didn't waste 350 bucks.
  11. Jul 17, 2019 at 6:30 AM
    Jasonsfirsttaco
    Put the old intake back in, for the little bit of HP you're gonna get on the higher RPM range its not worth the drop in gas mileage at all.
  12. Jul 17, 2019 at 7:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    HP Tuner. Nuff said.
  13. Aug 20, 2019 at 6:44 PM
    1997tacomav6
    Denver
    X2,
    I have had a K&N SINCE NEW, 600,000 miles, never had a problem
    Aw9d[QUOTED] likes this.
